FAO: CRT -- ECI Modem Latency Problem with G.INP
- FAO: CRT -- ECI Modem Latency Problem with G.INP
Re: FAO: CRT -- ECI Modem Latency Problem with G.INP
05-05-2015 9:10 PM
05-05-2015 10:01 PM
05-05-2015 11:15 PM
06-05-2015 12:38 AM
I think one thing should be made clear and that is the results of tests such as this, where the assumption is wrongly made that because there's no mention of retransmission, then the slowness isnt anything to do with G.INP.
"0.128M-80M Downstream, Interleaving Low - 0.128M-20M Upstream, Interleaving On"
What is being ignored is the fact if retransmission shows in the profile then all should be working correctly, because the modem is g.inp capable. The DLM only applies ReTX to modem routers that are capable of g.inp.
If the modem is G.INP incompatible, then the DLM falls over to applying the old style DLM so it wont ever show Retransmission in the profile.
Time and time again, we are seeing EU's being told that its not g.inp purely based on results such as above, yet those who have persevered and bought their own modem/routers have proved otherwise. There's several instances on this very forum where EU's have been told its not G.INP by CS reps only to find out that it is.
The point being is just because it doesnt say Retransmission in the DLM profile, it should not be taken as conclusive evidence that its not g.inp related.
For example there's one here but there are more.
06-05-2015 12:52 AM
Quote from: bustermissy1961 So how do i go about changing this ECI Modem from Openreach to a Huawei Modem.Can Plusnet arrange for one of Openreaches engineers to swap mine as i should have the Huawei Modem not this piece of [Censored].
The G.INP issue is a double-edged sword.
- We are seeing ISPs telling EU's that its not a G.INP issue because Retransmission isnt showing in the DLM profile
- We are seeing EU's jump on the bandwagon and wrongly blaming G.INP when their problem lies elsewhere.
So far from what has been said, we haven't seen anything one way or the other to be able to conclude if your issue is g.inp related or not.
For it to be possibly G.INP related, then _all_ of the following must be true:
- EU is using an ECI modem or other incompatible router.
- EU is on a Huawei cabinet. - How to check what type of fibre cabinet you are on
- EU has overnight lost circa 10Mbps of sync speed AND latency has doubled.
06-05-2015 9:59 AM
Quote from: plusnettony You are on G.INP, but I'm afraid we have no access to modems other than the ECI as far as I'm aware.
Are you saying that if an engineer came to complete my unfinished installation that OR *only* have ECI modems in stock?
Are *all* new installs getting ECI modems?
I don't believe you!
06-05-2015 10:05 AM
06-05-2015 11:02 AM
06-05-2015 11:20 AM
A few months back one of the Openreach engineers on my forum confirmed that for a while they could only get ECI's from their walk in supplies. The situation has since changed and both are now available, so its luck of the draw what your installer has on his van.
06-05-2015 7:47 PM
As this mess stands at the moment, with BT about to start a trial to try to fix / fudge this, the supplied equipment is not fully compatible and therefore, customers should at the very least, be given an option to replace the ECI for a Huawei when on a Huawei cab supplied using Kellys or BT engineers. Too simple or too expensive?
Is it not feasible that BT could get together with Plusnet and send out directly a new Huawei HG612 replacement for the ECI.
Also, what about vectoring when / if it does start nationwide, will this ECI modem work with that on a Huawei cab.
06-05-2015 8:47 PM
07-05-2015 8:04 AM
07-05-2015 8:17 AM
07-05-2015 9:47 AM
Quote from: jelv The Kellys engineer for my recent installation offered me an ECI, but when pushed he found a box of Huawei modems!
so future ebay stock been reduced then
07-05-2015 11:56 AM
