Drop in sync Speed
FIXED- Subscribe to RSS Feed
- Re: Drop in sync Speed
24-03-2022 4:05 PM
Hello all..
I had some building work done at home recently which necessitated cutting power to the house several times. As a result of this, my fibre downstream sync rate dropped from 79979Kbs to 73999Kbps. My previous connection had performed faultlessly for years prior to this event. I thought that over time this would increase back to something like the original speed, however it's been over a month now and showing no signs of improving.
If anyone can advise how long I need to wait before I am justified in raising this with Plusnet, I would be grateful.
Fixed! Go to the fix.
25-03-2022 9:22 AM
Good morning @hangar18, thanks a lot for getting in touch. Your line has been banded at 74Mbps, but has been for some time now, an RRT doesn't show a recent drop in sync speed.
Anyway, I've just raised a DLM reset request on our side to have the line unbanded, this'll complete within the next 3 working days.
25-03-2022 9:40 AM
Good morning Adam..
Thanks for your quick response and sorting this for me.
I hadn't noticed the drop until we had finished the building work, so not sure what would have caused the line to be banded.
Anyway, cheers 🙂
John.
25-03-2022 1:09 PM - edited 25-03-2022 1:09 PM
25-03-2022 2:07 PM
Hi Adam..
I had a new fuse box installed at home on the 23rd Feb. The electrician also did some circuit testing a couple of weeks prior to that and the power was cut several times over that period.. So that fits with the graph you've provided.
Anyway, thanks again and yes, I'll give you a shout if it persists.
25-03-2022 4:42 PM
Ah fair enough @hangar18, makes sense
28-03-2022 10:23 AM
28-03-2022 11:04 AM
Hi @adam945 ..
Just noticed the line speed at your end is still set to 71.2Mbps. Will this auto adjust to the new sync rate?
Cheers..
28-03-2022 2:30 PM
Hello @hangar18, I've just updated the L2TP profile on our side so this should now be sorted within the next few hours.
28-03-2022 2:54 PM
Thanks Adam 🙂
28-03-2022 5:31 PM
