Download speed stats
darkblak
I've just switched out modems - I've tried BT HH 5 & 6 but they were too poor for my liking and caused too many issues. Line drops etc I've switched to an ASUS DSL-AC88U - it's done wonders for Wifi in the house and it's got 4x1Gb ports on the back - very useful.
Now I want to get my speed back up to 79Mb that I originally had. Can anyone offer some advice on these stats below. The modem is on the latest official firmware.
System Log - DSL Log
This page shows the detailed system's activities.
DSL Driver Version A2pvfbH043g.d26p
DSL Link Status Link up
DSL Uptime 4 days 19 hours 3 minutes 9 seconds
DSL modulation VDSL2
ANNEX Mode ANNEX B
Current Profile 17a
TCM(Trellis Coded Modulation) ON
Line Status Downstream Upstream
SNR 6.3 dB 6.1 dB
Line Attenuation 9.6 dB 0 dB
Path Mode Interleaved Interleaved
Interleave Depth 1963 1
Data Rate 58187 kbps 19081 kbps
MAX Rate 71197 kbps 19237 kbps
POWER -5.8 dbm -5.7 dbm
CRC 5 1721
HEC 74 0
ES 12 1136
INP 4.00 symbols 0 symbols
 Further information:
FTTC is available in your area.
  Speed Max Min
  DownStream 80000 70300
  UpStream 20000 19000
3 REPLIES 3
Fixes: 1,601
Re: Download speed stats
Hi there.
Those stats indicate your router is in sync to the cabinet at 58mbps. As it's below your estimates, we can potentially raise this as a fault. However, what was your speed like with your Homehub plugged in?
It may also be worth running through the troubleshooting here
darkblak
I'll try that - but I have an openreach filtered faceplate specifically for ADSL - so I don't think it's going to make much difference. Any ideas why I am interleaved ?
Any thoughts on G.INP or stability Adjustment ? I am connected to an Infinion Exchange.
DSL modulation
ANNEX Mode
SRA (Seamless Rate Adaptation)
Bitswap
VDSL Profile
G.INP (G.998.4)
G.vector (G.993.5)
Stability Adjustment (ADSL)    Current Downstream SNR Margin: 6.3 dB
Fixes: 1,601
The test socket would essentially bypass the faceplate of the master socket.
Any ideas why I am interleaved ? Any thoughts on G.INP or stability Adjustment ? I am connected to an Infinion Exchange.
I believe this is handled by the DLM in the exchange and we've no way of changing its settings.
If your speeds remains slow in the test socket and you've tried the Homehub again, I'd recommend reporting a fault to us at http://faults.plus.net
