DLM adjustment on my line. GEA test requested
goldenfibre
Seasoned Pro
Fixes: 12
Look like my cabinet on my FTTC has changed DLM adjustment on my line.
Can Plusnet staff please ran the GEA test of my request. And post me result either here or inbox me.
5 REPLIES 5
MatthewWheeler
Fixes: 480
Re: DLM adjustment on my line. GEA test requested
GEA test below
Test Outcome Pass
Test Outcome Code GTC_FTTC_SERVICE_0003
Description No problem found, OAM test is not currently supported on this line.
Main Fault Location OK
Sync Status In Sync
Downstream Speed 79.9 Mbps
Upstream Speed 20.0 Mbps
Appointment Required N
Fault Report Advised N
NTE Power Status PowerOn
Voice Line Test Result Pass
Bridge Tap Not Detected
Cross Talk Not Detected
Estimated Line Length In Metres 243.6
Upstream Rate Assessment Very Good
Customer Traffic Level Upstream and Downstream Traffic Detected
Technology VDSL
Profile Name 0.128M-80M Downstream, Retransmission Low - 0.128M-20M Upstream, Error Protection Off
Time Stamp 2017-05-30T16:00:00
Parameters MIN MAX AVG
Down Stream Line Rate 79.9 Mbps 80.0 Mbps 79.9 Mbps
Up Stream Line Rate 19.9 Mbps 19.9 Mbps 19.9 Mbps
Up Time 513.0 Sec 900.0 Sec 899.2 Sec
Retrains 0.0 1.0 0.0
Current and Last 15 Minute Bin Performance
Parameters Last Traffic Count(Upto 15 mins) Current Traffic Count(Upto 15 mins)
Start Time Stamp 2017-06-12T14:28:32Z 2017-06-12T14:43:32Z
Ingress Code Violation 0 0
Egress Code Violation 0 0
Errored Seconds 0 0
Severely Errored Seconds 0 0
Unavailable Seconds 0 0
 Matthew Wheeler
goldenfibre
Seasoned Pro
Fixes: 12
Thanks Matthew. Look like my line are current very good! I thought my DLM put me on target SNR 3dB for the first time but it haven't.
Oldjim
Resting Legend
Fixes: 63
given that your line is in sync at full speed or course it wouldn't
Fixes: 1,601
Nothing wrong with those results that I can see.
I agree with Jim, you really can't get much more speed than the current sync rate I'm afraid.
goldenfibre
Seasoned Pro
Fixes: 12
I wish BT just uncapped 80Meg to go for 100/20 but I don't think it won't happen until G.Fast come along around 2025.
