DLM adjustment on my line. GEA test requested
- Re: DLM adjustment on my line. GEA test requested
12-06-2017 1:08 PM
Look like my cabinet on my FTTC has changed DLM adjustment on my line.
Can Plusnet staff please ran the GEA test of my request. And post me result either here or inbox me.
12-06-2017 3:58 PM
GEA test below
Test Outcome | Pass |
Test Outcome Code | GTC_FTTC_SERVICE_0003 |
Description | No problem found, OAM test is not currently supported on this line. |
Main Fault Location | OK |
Sync Status | In Sync |
Downstream Speed | 79.9 Mbps |
Upstream Speed | 20.0 Mbps |
Appointment Required | N |
Fault Report Advised | N |
NTE Power Status | PowerOn |
Voice Line Test Result | Pass |
Bridge Tap | Not Detected |
Radio Frequency Ingress | Not Detected |
Repetitive Electrical Impulse Noise | Not Detected |
Cross Talk | Not Detected |
Estimated Line Length In Metres | 243.6 |
Upstream Rate Assessment | Very Good |
Downstream Rate Assessment | Very Good |
Home Wiring Problem | Not Detected |
Downstream Policing Discard Rate | 0.0 |
Customer Traffic Level | Upstream and Downstream Traffic Detected |
Technology | VDSL |
Profile Name | 0.128M-80M Downstream, Retransmission Low - 0.128M-20M Upstream, Error Protection Off |
Time Stamp | 2017-05-30T16:00:00 |
Parameters | MIN | MAX | AVG |
Down Stream Line Rate | 79.9 Mbps | 80.0 Mbps | 79.9 Mbps |
Up Stream Line Rate | 19.9 Mbps | 19.9 Mbps | 19.9 Mbps |
Up Time | 513.0 Sec | 900.0 Sec | 899.2 Sec |
Retrains | 0.0 | 1.0 | 0.0 |
Current and Last 15 Minute Bin Performance | ||
Parameters | Last Traffic Count(Upto 15 mins) | Current Traffic Count(Upto 15 mins) |
Start Time Stamp | 2017-06-12T14:28:32Z | 2017-06-12T14:43:32Z |
Ingress Code Violation | 0 | 0 |
Egress Code Violation | 0 | 0 |
Errored Seconds | 0 | 0 |
Severely Errored Seconds | 0 | 0 |
Unavailable Seconds | 0 | 0 |
12-06-2017 8:16 PM
Thanks Matthew. Look like my line are current very good! I thought my DLM put me on target SNR 3dB for the first time but it haven't.
13-06-2017 9:40 AM
given that your line is in sync at full speed or course it wouldn't
13-06-2017 1:20 PM
13-06-2017 2:18 PM
I wish BT just uncapped 80Meg to go for 100/20 but I don't think it won't happen until G.Fast come along around 2025.
