DLM/GEA Check requested please
- Re: DLM/GEA Check requested please
23-05-2019 9:38 AM
Just switched over to Plusnet about 2 weeks ago but my speed has dropped by around 20% - from around 36/37Mb to 30/31.
It may be too early in terms of the DLM but can someone check what my DLM band is and also any GEA check?
Can my DLM be reset or forced up at all to try and match my previous speeds...?
My SNR is hovering around 6.
Thanks!
23-05-2019 10:46 AM
When you change provider Openreach reset the DLM to 6dB. If your line will support it then this should drop to around 3 with a resultant increase in speed. Unless your line is banded you just have to be patient and wait for it to update automatically.
23-05-2019 12:13 PM
Thanks for your post @mrshed.
On running a GEA test we can see that the SNR is currently at 3db with the banding for the line looking correct:
GEA Test Detail | |||
Circuit ID | <REDACTED> | Service ID | <REDACTED> |
Test Outcome | Pass | ||||
Test Outcome Code | GTC_FTTC_SERVICE_0000 | ||||
Description | GEA service test completed and no fault found . | ||||
Main Fault Location | OK | ||||
Sync Status | In Sync | ||||
Downstream Speed | 27.7 Mbps | ||||
Upstream Speed | 5.5 Mbps | ||||
Appointment Required | N | ||||
Fault Report Advised | N | ||||
NTE Power Status | PowerOn | ||||
Voice Line Test Result | Pass | ||||
Bridge Tap | Not Detected | ||||
Radio Frequency Ingress | Not Detected | ||||
Repetitive Electrical Impulse Noise | Not Detected | ||||
Cross Talk | Detected | ||||
Estimated Line Length In Metres | 975.4 | ||||
Upstream Rate Assessment | Low | ||||
Downstream Rate Assessment | Reasonable | ||||
Interference Pattern | Regular Interference Observed Daily | ||||
Service Impact | No Impact Observed | ||||
Interference Duration Longest Occurrence | No Timing Information | ||||
Interference Location | Customer Premise | ||||
Interference Observed In Days | 2 | ||||
Home Wiring Problem | Not Detected | ||||
Downstream Policing Discard Rate | 0.0 | ||||
Customer Traffic Level | Upstream and Downstream Traffic Detected | ||||
Technology | VDSL | ||||
Profile Name | 0.128M-40M Downstream 3dB, Retransmission High - 0.128M-10M Upstream, Error Protection Off | ||||
Time Stamp | 2019-05-10T12:15:00 |
Parameters | MIN | MAX | AVG |
Down Stream Line Rate | 25.4 Mbps | 37.5 Mbps | 30.3 Mbps |
Up Stream Line Rate | 5.3 Mbps | 7.1 Mbps | 6.0 Mbps |
Up Time | 0.0 Sec | 900.0 Sec | 897.2 Sec |
Retrains | 0.0 | 1.0 | 0.0 |
Current and Last 15 Minute Bin Performance | ||
Parameters | Last Traffic Count(Upto 15 mins) | Current Traffic Count(Upto 15 mins) |
Start Time Stamp | 2019-05-23T10:36:38Z | 2019-05-23T10:51:38Z |
Ingress Code Violation | 0 | 0 |
Egress Code Violation | 0 | 0 |
Errored Seconds | 0 | 0 |
Severely Errored Seconds | 0 | 0 |
Unavailable Seconds | 0 | 0 |
The only slight concern is that it's detected CrossTalk, however on testing the line further we aren't seeing anything that could be construed as an issue, with copper line tests showing clear.
We'd recommend giving it another week or so for the line speed to pick up.
