Connection Down
TerryCTR
Connection Down
As per the title I have came home from work around 6 and noticed the router flashing orange. Tried the usual reset but to no avail.
I am unable to raise a ticket on the member centre as each time I try to login it says the service is temporarily unavailable.
Can someone have a look at this?
I assume a credit will be issued to cover the down time?
Terry
7 REPLIES 7
Fixes: 1,485
Re: Connection Down
Really you need to be phoning them and getting a fault raised
TerryCTR
Re: Connection Down
I'd rather raise a ticket online than sit and wait to get put through
Chris
Legend
Fixes: 169
Re: Connection Down
I've just checked and there's a local outage showing, due to be resolved this evening around 530pm.
TerryCTR
Re: Connection Down
Thanks for the update, it's still down at this point.
Credit on my account I assume
Fixes: 1,485
Re: Connection Down
I suspect that would be unlikely
TerryCTR
Re: Connection Down
Why not, it's still down so I'm paying for something that isn't working
Chris
Legend
Fixes: 169
Re: Connection Down
I'm afraid outages like this are not something we refund for as they are outside of our control, sorry.
