Can I have a GEA test done please.
- Re: Can I have a GEA test done please.
- « Previous
- 1
- 2
- Next »
19-08-2017 8:29 AM
Just giving this a bump incase PN staff missed my request.
21-08-2017 3:23 PM
@Malcky GEA test below. Are you still seeing issues?
Test Outcome | Fail |
Test Outcome Code | GTC_FTTC_SERVICE_1625 |
Description | Impairment in copper joint detected most likely in local network. Please continue to submit a trouble report |
Main Fault Location | LN |
Sync Status | In Sync |
Downstream Speed | 79.2 Mbps |
Upstream Speed | 20.0 Mbps |
Appointment Required | N |
Fault Report Advised | Y |
NTE Power Status | PowerOn |
Voice Line Test Result | Pass |
Bridge Tap | Not Detected |
Radio Frequency Ingress | Detected |
Repetitive Electrical Impulse Noise | Not Detected |
Cross Talk | Detected |
Estimated Line Length In Metres | 538.7 |
Upstream Rate Assessment | Very Good |
Downstream Rate Assessment | Very Good |
Interference Pattern | Not Detected |
Service Impact | No Impact Observed |
Home Wiring Problem | Not Detected |
Downstream Policing Discard Rate | 0.0 |
Customer Traffic Level | Upstream and Downstream Traffic Detected |
Technology | VDSL |
Current 15Min Bin Retrains | 0 |
Last 15Min Bin Retrains | 0 |
Profile Name | 0.128M-80M Downstream, Retransmission Low - 0.128M-20M Upstream, Error Protection Off |
Time Stamp | 2017-08-16T11:15:00 |
Parameters | MIN | MAX | AVG |
Down Stream Line Rate | 79.2 Mbps | 79.2 Mbps | 79.2 Mbps |
Up Stream Line Rate | 20.0 Mbps | 20.0 Mbps | 20.0 Mbps |
Up Time | 898.0 Sec | 900.0 Sec | 899.9 Sec |
Retrains | 0.0 | 0.0 | 0.0 |
21-08-2017 4:09 PM - edited 21-08-2017 4:11 PM
Thanks for the new results....the phone line now works for phone calls and as far as I can tell the internet side of things seems to be ok as well.......but the info on the table you have supplied is showing the following errors that were not there last week:
Test Outcome: Fail. ---- Impairment in copper joint detected most likely in local network. Please continue to submit a trouble report
Radio Frequency Ingress: Detected
Crosstalk: Detected
How come the line length is way different in the two results?....372.9m then 538.7m
Although the sync figures don't look like an error and speed test I do seem to be fine.....I would like the line to be double checked if faults are showing.
Edit: Does any of your systems show if I have G.INP enabled on my line?
- « Previous
- 1
- 2
- Next »
