Banded again
FIXED- Subscribe to RSS Feed
- Banded again
25-10-2019 2:47 PM
Hi
Would it be possible to have the banding lifted from my line.
Historically I have been connected at between 75-80kbits/s and something happen in August which dropped the speed to 60 kbits/s, a fault was raised and BTW man said there s nothing wrong with the line and it should connect at at least 75 kbits/s, he also changed the fibre port and reset the DLM. It went back to the slower speed very quickly after the reset.
Since these events BTW have been doing some work on other pairs in the same cable to fix faults for a neighbour and I was connected for 3 weeks until 2 resent power fails.
All connected computers are wired connections
HG612 straight into NTE5C mark4 with built in splitter no telephone extension wiring.
Attached speed test and BTW checker
Thinkbroadband BQM from a weekend showing how much we require the extra bandwidth
xdslcmd info --stats
xdslcmd: ADSL driver and PHY status
Status: Showtime
Retrain Reason: 0
Last initialization procedure status: 0
Max: Upstream rate = 23398 Kbps, Downstream rate = 82564 Kbps
Bearer: 0, Upstream rate = 19999 Kbps, Downstream rate = 60000 Kbps
Bearer: 1, Upstream rate = 0 Kbps, Downstream rate = 0 Kbps
Link Power State: L0
Mode: VDSL2 Annex B
VDSL2 Profile: Profile 17a
TPS-TC: PTM Mode(0x0)
Trellis: U:ON /D:ON
Line Status: No Defect
Training Status: Showtime
Down Up
SNR (dB): 10.4 12.4
Attn(dB): 18.6 0.0
Pwr(dBm): 13.8 7.4
VDSL2 framing
Bearer 0
MSGc: -6 26
B: 122 237
M: 1 1
T: 0 42
R: 8 16
S: 0.0647 0.3781
L: 16186 5374
😧 8 1
I: 131 127
N: 131 254
Q: 8 0
V: 7 0
RxQueue: 136 0
TxQueue: 34 0
G.INP Framing: 18 0
G.INP lookback: 31 0
RRC bits: 0 24
Bearer 1
MSGc: 122 -6
B: 0 0
M: 2 0
T: 2 0
R: 16 0
S: 8.0000 0.0000
L: 32 0
😧 1 0
I: 32 0
N: 32 0
Q: 0 0
V: 0 0
RxQueue: 0 0
TxQueue: 0 0
G.INP Framing: 0 0
G.INP lookback: 0 0
RRC bits: 0 0
Counters
Bearer 0
OHF: 0 3008423
OHFErr: 29 144
RS: 3501406928 3992019
RSCorr: 4653737 799
RSUnCorr: 0 0
Bearer 1
OHF: 12232591 0
OHFErr: 0 0
RS: 97860233 0
RSCorr: 3172 0
RSUnCorr: 0 0
Retransmit Counters
rtx_tx: 2998879 0
rtx_c: 598439 0
rtx_uc: 32 0
G.INP Counters
LEFTRS: 493 0
minEFTR: 60001 0
errFreeBits: 179676004 0
Bearer 0
HEC: 0 0
OCD: 0 0
LCD: 0 0
Total Cells: 1182795982 0
Data Cells: 685205215 0
Drop Cells: 0
Bit Errors: 0 0
Bearer 1
HEC: 0 0
OCD: 0 0
LCD: 0 0
Total Cells: 0 0
Data Cells: 0 0
Drop Cells: 0
Bit Errors: 0 0
ES: 19 128
SES: 19 0
UAS: 31 31
AS: 196489
Bearer 0
INP: 52.00 0.00
INPRein: 1.00 0.00
delay: 0 0
PER: 0.00 3.98
OR: 0.01 64.22
AgR: 60553.63 20063.54
Bearer 1
INP: 2.00 0.00
INPRein: 2.00 0.00
delay: 0 0
PER: 16.06 0.01
OR: 63.75 0.01
AgR: 63.75 0.01
Bitswap: 154595/154595 333/334
Total time = 1 days 6 hours 35 min 20 sec
FEC: 4653737 799
CRC: 29 144
ES: 19 128
SES: 19 0
UAS: 31 31
LOS: 0 0
LOF: 0 0
LOM: 0 0
Latest 15 minutes time = 5 min 20 sec
FEC: 0 0
CRC: 0 0
ES: 0 0
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
Previous 15 minutes time = 15 min 0 sec
FEC: 26490 0
CRC: 0 0
ES: 0 0
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
Latest 1 day time = 6 hours 35 min 20 sec
FEC: 993476 141
CRC: 1 35
ES: 1 27
SES: 1 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
Previous 1 day time = 24 hours 0 sec
FEC: 1587121 363
CRC: 7 62
ES: 4 57
SES: 4 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
Since Link time = 2 days 6 hours 34 min 49 sec
FEC: 4653737 799
CRC: 29 144
ES: 19 128
SES: 19 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
Fixed! Go to the fix.
Re: Banded again
25-10-2019 3:25 PM
I'm arranging for a DLM reset to be carried out remotely which should go through within the next few days although with the weekend ahead of us you may not see any improvement until mid-next week.
Let us know how it goes.
Re: Banded again
26-10-2019 2:45 PM
DLM reset at 04:40 this morning and it would appear it has gone straight to a banding of 66997kbits/s which is an improvement, I will continue to monitor it over the coming week.
Re: Banded again
27-10-2019 1:35 PM
Thanks for letting us know @zpeterk
Glad to hear the DLM reset made an improvement.
Keep an eye on things and get back to us if you notice further problems.
Re: Banded again
30-10-2019 9:01 PM
Around 16:00 today disconnect and resync presumably by dlm to 76037 with a snr of 6.3 hopefully this will continue.
Thank you to support team
31-10-2019 11:50 AM
Re: Banded again
12-11-2019 9:36 AM
Update: Had a resync at 05:10 now connected 79949kbs and SNR margin 5.3, back to where we were in July, not bad at 595m to the box (as reported by btw man).
Thanks again
Re: Banded again
12-11-2019 1:34 PM
That's brilliant news @zpeterk, we're thrilled that it's seemingly sorted.
Keep an eye on it over the next week or so and let us know how you get on with it.
If anything deteriorates, please get in touch here and we'll get onto it ASAP.
