Authentication Failure?
- Re: Authentication Failure?
04-03-2016 9:38 AM
As I was leaving for work this morning I noticed that the light on my router was flashing orange (Airport Extreme) meaning no auth with Plusnet, DSL is in sync. I have also discovered that a work colleague also Plusnet and also on Haslington (Crewe) exchange is also off. Maintenance or something else?
Message 1 of 8
(1,554 Views)
7 REPLIES 7
04-03-2016 2:55 PM
Message 2 of 8
(769 Views)
04-03-2016 4:19 PM
HarryB, Thank you I'll try that when I get home. I did try a quick reboot of the router before I left for work with no change.
I have noticed with the AE that sometimes it will re-connect after an outage and sometimes it won't (mostly it doesn't )
Message 3 of 8
(769 Views)
04-03-2016 11:52 PM
@HarryB, rebooted the router when I got home and all is back to normal.
Message 4 of 8
(769 Views)
05-03-2016 1:39 AM
Message 5 of 8
(769 Views)
05-03-2016 6:16 PM
Message 6 of 8
(769 Views)
05-03-2016 10:21 PM
@nbk, now on gateway psb-ar01. I guess this must be the new network.
Message 7 of 8
(769 Views)
06-03-2016 12:13 AM
Yes, that's on the new network.
David
Message 8 of 8
(769 Views)
