Big speed drop on FTTC
TCB123
I originally had a download speed of about 46Mbps which was stable for many months. It has since dropped to about 31Mbps. I contacted Plusnet support and they said this was normal and not a fault. Someone else on this forum with a much smaller speed drop has been told this is a fault:
http://community.plus.net/forum/index.php/topic,148789.0.html
What is the truth here?
HughPH
Re: Big speed drop on FTTC
The other post says that the service IS AFFECTED BY AN EXISTING NETWORK EVENT - the way I would read that would be that they know what caused it (e.g. some nearby works that may have generated a lot of RFI/EMI) and that there is no electrical fault detected. In those circumstances I would expect the speed would recover after a little while (after the noise has gone) although it might be necessary for an engineer to manually trigger that recovery.
To say that this is "the same" would need more investigation and more detail - but the symptoms are the same, so it's likely to be a similar issue: a temporary event that caused localised excess noise affecting broadband lines in the area.
In the worst case, it's a non-temporary issue - i.e. someone's installed something that generates a lot of RFI/EMI near the phone line. I should be syncing at 28000Kbps but I only get 25000Kbps because there is something near my line that regularly spanners it with 2dB of noise - I've been producing graphs from the stats in the modem and I can see it sometimes drop for 15 minutes and then recover, and other times it drops for 48 hours and only recovers for 10 minutes. The way it turns on and off, I strongly suspect there's some nearby hardware (e.g. the farmer's generator) causing the noise.
SpendLessTime
Aspiring Hero
Fixes: 54
@TCB123
As the BTW tests are showing red, I would log a fault at http://faults.plus.net/
Something is amiss and the red on the chart indicates that Plusnet should get their supplier (BTW) to check for faults.
TCB123
I have already done that and was told there was no fault even though I had lost a third of my download speed and the chart was red.
mav:quote
Fixes: 31
How are you testing, wired or wireless?
I have noticed the BTW site gives out odd results at times.
Are you able to print out a copy of your routerstats/Helpdesk page?
TCB123
I have a Draytek 3130N router connect via the BT box directly to the master socket. No wireless involved.
dick:quote
Plusnet Staff
Plusnet Staff
Fixes: 116
Hello there. From the information you've provided here, the router is syncing at 32.4 Mb which is under the speed estimate you linked. The next step would be to plug the router into the test socket (behind the master socket). If the sync hasn't improved and you've tried a different router, then I would recommend commenting on the fault ticket (or raising it again if it has timed out), making our faults team aware that the router is syncing too low.
Hope this helps
From when I joined the Plusnet Help Team in May 2017 my main Community account is @Gandalf.
 Plusnet Staff
TCB123
I don't think I can connect to behind the master socket for a long test as this would mean disconnecting our phone.
I have a Huawei HG612 B3 modem which I assume is doing the syncing and nothing else to try. My Draytek router plugs directly into the modem.
dick:quote
TCB123
I have been reading up about the effect of crosstalk and could this be my problem?
My speed started stably and about 46. After a year or more it dropped to be stable at about 40 (If I remember right). Now it has dropped to be stable at about 32. Could be when other people were connected up?
Quote from: TCB123
I think a photo is called for a proper mk3 socket has separate phone  and broadband sockets so that your phone can stay connected while you remove the bottom plate to access the test socket. The filtering is built in with the mk3 too  Sad
/ edit I've got it the wrong way round testing is wth the phone disconnected as the OP states  Roll eyes
To do is to be - Neitzsche
To be is to do - Kant
do be do be do - Sinatra
Terranova667
Quote from: TCB123
Hard to say it could be crosstalk  then again it could be a fault that is able to be fixed you wont know until a Engineer does some tests, get back to support and tell them you want a engineer visit booked your under the required Estimate don't take no for a answer.
