Any problems on Plusnet this weekend ?
waynem41
My internet speeds areall over the place , waiting  ages for pages to load etc.
I'm on 80 Mb fibre , I'm close to the cabinet and connect at 78Mb .
Just ran a speed test and got a result of 1.39Mb  Cry
Anyone else noticing problems or is it just me ?
17 REPLIES 17
alext05
Re: Any problems on Plusnet this weekend ?
Now you mentioned it.
<a href="http://www.speedtest.net/my-result/4399256415"><img src="http://www.speedtest.net/result/4399256415.png" /></a>
Normally get 64Mbps.
Angry
bobandwendy
heres mine,a bit faster than your connection ,strange when you think I'm actually on a slower connection than you and mine is extremely slow as well
alext05
Could it be because the Countryfile is on? Grin
tijara33
Fixes: 6
Something is really wrong. I'm on pcl-bng02 & my speeds are all over the place, down in SP6.
simoncraddock
Seems ok here on pcl-bng02
tijara33
Fixes: 6
The workings of the internet are indeed, a deep mystery!  Undecided
southerner
My connection seems to suck tonight too. Down from 75 to the 50s ds and from 15 to 3 us with a general sluggishness. Assume it's just the peak slowdown?
Alucidnation
Tonight?
Its crap EVERY night...
rongtw
Fixes: 12
Especially on BNG  Embarrassed
waynem41
Got off pcl-bng03 onto ptw-ag03 via the Disconnect / Connect tab on the routers webpage but it doesn't seem to have made a difference.
Running several speed tests I can get  results of over 40Mb  but another test a few minutes later is less than 1Mb ?
elfish
pcl-bng03 has been good to me today (40/20):
southerner
I did a TAP3 test connected to the Speedtest domain & it gave the same poor results I had when logged into Plusnet so does that suggest for me the congestion is between my cabinet & exchange? Am I right in thinking that test doesn't even get to Plusnet's network? The Speedtest site said poor result & to report to ISP. I might add it to my ticket.
elfish
Does suggest that it maybe congestion within BT's network (area specific) rather than PlusNet's network. I'm in the NW (connected through Preston MSE) and it has been fine today.
keyholder
CV10 area seems ok speed wise for me
Although Gaming still pointless and Ping monitor says different
