Any capacity issues?
- Any capacity issues?
Re: Any capacity issues?
21-01-2015 8:59 PM
21-01-2015 9:55 PM
Tonight once again there are issues with a lot of jitter and associated latency increase, this does differ slightly depending on the destination traced, but once again i have slow throughput this time it's also affecting multi threaded downloads and the upstream isn't good either, here's what i mean and this
How long do plusnet expect people to tolerate this almost nightly interruption in service with no proper answers and no solution in sight ?
And other observations that i have made are that the number of customers connected to a gateway makes no real difference, to throughput,ect, the only differences in gateways i have found is that the newer BNG's do provide a small increase in headline throughput over the older gateways, the latency difference could be down to the gateway config, or the central ( 10 or 11) or the particular endpoint so can sometimes appear to change
21-01-2015 10:05 PM
Anyways
I hopped a lot and i didnt see much slowdown...the throughput on some of the gateways was up and down but i'm currently on ptw-bng02 seeing pretty stable speeds
I tend to avoid the pcl gateways because they're usually the ones I have trouble with 😐
Pic below of 10pm when i remembered to shut off the stream I was watching
Actually I figured I'd post all 3 today! Or more...
The 5pm and 6pm are on a pcl gateway, the rest are on ptw-bng02
The reason I switched was the pcl gateway was starting to look erratic...
In hindsight I should have stayed on it and looked at it throughout the night
But at the peak times at 7pm, 8pm, 9pm, 10pm...you can see it's very very stable throughput with pretty much no divergence between the TBB test and HTTP.
21-01-2015 11:00 PM
Anyway as predicted as we approach 11pm throughput is starting to normalize the upstream is operating as intended again the downstream is getting somewhere near
last night ping grap shows the packet loss stop when i swapped gateways , and tonight's laggy peak time ping monitor And the usage graphs IMO tally with the slow downs ect what i and others are seeing every night most of which used to be limited to 1-2 days a week, now its present on a daily basis http://i.imgur.com/5kubpVD.jpg
21-01-2015 11:03 PM
Quote from: deathtrap Interesting why only the 2 speedtests carried out pre peak time @16:58 and again @18:00 have the ISP tag displayed on them all the others following those dont have the identity of the ISP on them they are marked unknown , every time that i have used the think broadband speedtester it has always identified my ISP /IPblock correctly , so those tests to me are not conclusive as without evidence of which isp's connection used they could belong to any other isp couldn't they
There's a good reason for that...
It's definitely Plusnet even if some applications think I'm american
Also if you don't trust mine then you can't trust anybodys TBB speed test since it's easy to change what ISP it displays via the drop down menu.
21-01-2015 11:20 PM
22-01-2015 1:19 AM
Jan 22 01:14:05 TomatoAC66 daemon.info pppd[23111]: No response to 6 echo-requests
Jan 22 01:14:05 TomatoAC66 daemon.notice pppd[23111]: Serial link appears to be disconnected.
Jan 22 01:14:05 TomatoAC66 daemon.info pppd[23111]: Connect time 4234.8 minutes.
Jan 22 01:14:05 TomatoAC66 daemon.info pppd[23111]: Sent 1013133175 bytes, received 2428276140 bytes.
Jan 22 01:14:11 TomatoAC66 daemon.notice pppd[23111]: Connection terminated.
Jan 22 01:14:11 TomatoAC66 daemon.notice pppd[23111]: Modem hangup
Jan 22 01:14:15 TomatoAC66 user.info redial[23112]: WAN down. Reconnecting...
If I am on a slow endpoint now I will stay on it until friday evening and report the slow speeds.
23-01-2015 12:56 AM
Proper gateway issues. The first pic is on ptn-bng01...good speeds, mostly stable, no divergence between HTTP and TBB tests.
The second pic is on pcl-bng02 at 12.46am. That one is all over the show
23-01-2015 11:52 AM
I'm still passing this information on to the team. They're investigating what could be causing the slowdowns and are collating the data you're providing as part of this.
23-01-2015 2:38 PM
I posted yesterday about the increase of users but this was expected due to the number of endpoints or something.
http://www.plus.net/support/service/network_performance/broadband_bandwidth_usage.shtml
23-01-2015 5:20 PM
Nothing we're aware of.
Update to the others in this thread:
We've continued looking at this from multiple angles and our testing is pointing towards SVLAN usage. We can't see anything wrong with our network, endpoints etc.
goldenfibre - AMBER
nbk - AMBER
chrocoluk - AMBER
tonyAtplus - AMBER
Melancholie - Resolved(ish) - http://community.plus.net/forum/index.php/topic,135389.msg1191813.html#msg1191813
The SVLAN reports updated earlier this week and we've been through KBD tests with the above results showing.
And we've just checked a secondary data source and they *aren't* all amber. We're still investigating anyway!
23-01-2015 5:54 PM
AAISP certainly have a few cases for this on-going at the moment in the South West and parts of London.
23-01-2015 7:09 PM
I live now where near those locations, and those issue have been ongoing since 8/1/15 https://aastatus.net/2065
23-01-2015 7:10 PM
23-01-2015 7:41 PM
