Any capacity issues?
- Any capacity issues?
Re: Any capacity issues?
23-01-2015 7:45 PM
Anyone been able to check with friends/neighbours with 21CN ISPs on the same exchange?
23-01-2015 8:38 PM
23-01-2015 8:45 PM
Quote from: Chris Update to the others in this thread:
We've continued looking at this from multiple angles and our testing is pointing towards SVLAN usage. We can't see anything wrong with our network, endpoints etc.
snip/... /snip
The SVLAN reports updated earlier this week and we've been through KBD tests with the above results showing.
And we've just checked a secondary data source and they *aren't* all amber. We're still investigating anyway!
Do I not count?
I did a whole page full of fairly extensive tests for you showing progress throughout the nite. Because I was being nice and trying to be patient is that why mine were totally ignored?
This is tonight. (central11.pcl-bng01)
Also attached http download - you can see how poor things are. Im on a full 80/20 sync, but during peak I only seem to be able to get 20-30Mbps max.
afaik Im on SFBB00004858 which is BLUE
Edited to add central no
23-01-2015 8:52 PM
Where would pn users be with out aaisp looking into things.......
No issues here, dispite heavy use to highlight deathtraps post
23-01-2015 9:09 PM
Quote from: Webif Where would pn users be with out aaisp looking into things.......
True
23-01-2015 9:12 PM
I doubt it's a Svlan congestion issue at my exchange based on what I'm seeing
23-01-2015 9:30 PM
Quote from: Webif Does seem these days if you poilte & nice things get "missed/overlooked"
Well now I will openly state that I am royally peed off that no-one even bothered to acknowledge the testing that I did..... Im like that. Normally pretty patient until overlooked and then I BITE!
... so now try tell me that its local. Ive just been doing a gateway hop (ppp not resync). When on pcl-bng01 I couldnt get much above 25Mbps.
Just got on central12.pcl-bng02 and now look. I think that pretty much rules out a problem at my end. - Over to you Plusnet!
23-01-2015 9:32 PM
23-01-2015 9:38 PM
23-01-2015 9:52 PM
Still seems ok here as far as downloads are concerned, but latency seems possibly a tad more jittery when performing a trace to my server.
Im staying on here for now, because this is the best peak time speed Ive had for ages. I think the fact that I couldnt get much above 25Mbps when on pcl-bng01 shows without doubt there is a problem with some of their endpoints.
ETA
Hmmm Im not quite sure if all is fine and dandy here. I seem to be seeing some sort of weird jitter and/or packet loss. Look at my throughput graph again in my post above, see how Im getting some kind of weird stutter. That graph should be a red block, not have missing segments where packets have been lost. Just checked my line stats, they're not CRCs.
23-01-2015 10:25 PM
Quote from: kitz ... so now try tell me that its local. Ive just been doing a gateway hop (ppp not resync).
May be missing something but what would a VDSL resync change on the fibre side of the cabinet that a PPP reconnect wouldn't?
23-01-2015 10:26 PM
23-01-2015 10:31 PM
Quote from: Melancholie
I can't see that it could change anything certainly not of the BT networking side of things,to the core network,
24-01-2015 12:18 AM
Quote from: AndyH I think the fact that all those users can re-connect and get normal speeds again is showing it might be BTW backhaul after the SVLANs.
AAISP certainly have a few cases for this on-going at the moment in the South West and parts of London.
do BTw have any monitoring for backhaul after the SVLANs?
24-01-2015 12:23 AM
kitz I was going to ask you to hop, and you did it, thanks.
