After switching from BT to Plusnet DNS servers are still BT?
doop
hi
i was just trying to find my what my IP was when i noticed that the DNS servers are BTs?
81.139.57.75 - Hostname None ¦ ISP BT
81.139.57.76 - Hostname None ¦ISP BT
81.139.57.44 - Hostname indnsc135.bt.net ¦ ISP BT
81.139.57.43 - Hostname indnsc134.bt.net ¦ISP BT
Have Openreach messed up and not switched me properly?
thx
Also my IP is Plusnet not BT
8 REPLIES 8
Mustrum
Fixes: 77
Re: After switching from BT to Plusnet DNS servers are still BT?
Is that not due to you not using a PN Router and you not changing DNS servers within that router?
doop
Hi
this is a brand new router never used before I got Plusnet, and it has been updated and factory rebooted.
Mustrum
Fixes: 77
Which router is it?
Oldjim
Resting Legend
Fixes: 63
Have you have selected Safeguard as that uses BT's DNS servers
doop
Its a Linksys router
and i am NOT using safeguard
Browni
Aspiring Hero
Fixes: 60
I'm using a Hub One and the DNS are
Primary DNS: 212.159.6.9  cdns01.plus.net
Secondary DNS: 212.159.6.10  cdns02.plus.net
30FTTC06
Fixes: 4
I had a strange problem with dns servers when I first moved back from bt, It took weeks to sort itself out.
there was no explanation from plusnet either!
Linky
I wouldn't bother reading past the first page... I must of been on me pills!
ejs
Aspiring Hero
Fixes: 25
@doop
What did you use to find those DNS IP addresses? A router wouldn't usually be configured with 4 DNS servers.
