Abysmal fibre broadband speed
- Abysmal fibre broadband speed
- « Previous
- 1
- 2
- Next »
Re: Abysmal fibre broadband speed
19-05-2018 12:00 PM
A BIG apology to Plusnet for even thinking that they were throttling my line speed.
I connected using an Ethernet cable and my speeds magically increased - almost threefold!
So, I have a problem with WiFi but is it the router or my 6-year old Fujitsu laptop? I guess I need to connect to a router that is known to be delivering high speed connections as a first step.
Thanks for all your help.
19-05-2018 1:46 PM
All is well in Grumpyland I reckoned that the inbuilt network adapter on my laptop was a bit ancient so replaced it with a new one. Problem sorted.
Again, my thanks to everyone who helped me on this problem.
19-05-2018 2:42 PM
Good to hear things are fixed.
WiFi reception is a dark art which can be notoriously difficult to fix if poor. Indeed most ISP's will not look at it if your connection is working fine - it's not their problem unless you can prove a faulty router.
- « Previous
- 1
- 2
- Next »
