ADSL to Fibre Plus today....
DogTog
My date for upgrading is today, I received my new router/hub a few days ago, how will I know when the service has swapped over and when to install the new router?
5 REPLIES 5
Fixes: 1,485
Re: ADSL to Fibre Plus today....
You can use the Hub One on both ADSL / VDSL so you should be able to pl;ug it in straight away and it should swtich automatically when your service does.
DogTog
Oh great, I'll attempt that now.
DogTog
Ok, hub install went smooth and am up and running (on ADSL) with this. Will I get an email to say it's changed over to fibre plus or just keep checking on a speed checker etc?
Fixes: 1,485
You should get notification from PN when the switch is completed, but you can also check in the routers web interface (http://192.168.1.254) so see how it's connected.
Your connection will drop for a time so you may well notice that.
SammyM
Fixes: 98
Hello @DogTog,
Thanks for getting in touch and welcome to the forums. You will receive a notification once the order has completed and this will be anytime up to midnight on the 20/11/2019.
Please get back to us if you have any further queries.
 Sammy M - Sheffield Team
