Noise Margin query
FIXED- Subscribe to RSS Feed
- Noise Margin query
18-11-2019 9:12 AM
6 Days, 22 Hours 42 Minutes 52 Seconds
6.63 Mbps / 35.00 Mbps
6848 / 39288
6.5 dB / 2.6 dB
25 dB
0 dB / 25 dB
Fixed! Go to the fix.
18-11-2019 3:17 PM
Thanks for your post @fred77
Having a low noise margin isn't necessarily always a bad thing as it allows you to get the highest speeds possible. In some cases, it can make the line too fast causing errors however this is seen more on standard broadband rather than fibre broadband.
With regards to the upload speed being consistently at 6mbps it will most likely be that is the highest upload speed you can get. There are many factors which can affect your speeds but the most common are
- The distance of the line between your property and the cabinet. If you're quite far away you'll get poorer speeds but the closer you are the better speeds you'll get
- If any section of the line between your property and the cabinet is aluminium. This doesn't work great on fibre and it can make your line appear longer then it is
- Crosstalk which is electrical interference from other lines on Fibre. This can gradually bring your speeds down over time as more people move over to Fibre.
Let us know if there's anything else we can help with
Re: Noise Margin query
19-11-2019 11:00 AM
Thanks Mathew for the info. That helps.
Cheers,
