trying to install smf
- Everything else
- Re: trying to install smf
- « Previous
- Next »
07-09-2007 12:50 PM
Ok had a reply to my ticket from the tech guys, they have updated my DNS settings again and they now look like this.
Lets hope this works.
Left field | Type | PRI | Right field |
MX | 20 | mx.last.plus.net. | |
www | cname | ccgi.username.plus.com. |
Message 31 of 34
(354 Views)
07-09-2007 2:01 PM
Looking at that record it will do exactly the same as ccgi.plus.net.
The reason for this could be the way you actually set up the forum initially. Normally when you go through a setup it asks you the URL of the forum, if you typed in ccgi.username.plus.com then this would explain it, this is likely to be the case too as you set the forum up before we pointed your domain at it.
Quote I type in www.domain.co.uk/forum, it takes me to my forum, then any page i goto after that its http://ccgi.username.plus.com/forum
Message 32 of 34
(354 Views)
07-09-2007 2:04 PM
I've just double checked on mine and I also had it set up that way.
Log in to the admin panel, then from the menu choose Server Settings, browse down to the Forum URL and alter this to www.domain.co.uk/forum
Message 33 of 34
(354 Views)
07-09-2007 8:20 PM
Finally - Success, my board now always points to www.domain.co.uk - Thanks to everyone who helpad and gave advice.
Jason
Jason
Message 34 of 34
(354 Views)
- « Previous
- Next »
- Everything else
