reset ccgi webspace
stuck
Fixes: 4
reset ccgi webspace
I have legacy ccgi webspace, but I don't have a domain name.  I've not used this webspace for a while and so the small amount of content on it is redundant.  In anticipation of the migration to Greenby, I'd like to reset this webspace back to a default state.
Is there a simple way to do that?
3 REPLIES 3
Tina11192
Fixes: 18
Re: reset ccgi webspace
Hey @stuck Thank you for reaching out to us on our Community Forum, i hope you are well.
Please follow this link to the open ticket on your account: https://www.plus.net/wizard/?p=view_question&id=248794236
I hope this helps
Cri Ignatti
stuck
Fixes: 4
@Tina11192
Thank you, I have added more details to that question.
Tina11192
Fixes: 18
Hi there @stuck thank you for your response, I have now raised the task and sent you the details through email, I will be back in touch with you once they have completed it.
I hope this helps
Cri Ignatti
