remove username from hostname
katga
I've seen a few posts also raising this issue. I would like my username to be removed from my hostname (I just setup a static ip address with plusnet).
seems to be set to. [username].plus.com, please anonymise it.
I assume it set that way for companies
4 REPLIES 4
Fixes: 480
Re: remove username from hostname
Moderators Note
This topic has been moved from Broadband to Everything Else
katga
I saw this post and a few others where a ticket has  to be raised for the NetOps teams to fix. I assume only customer support can riase these tickets
https://community.plus.net/t5/Fibre-Broadband/Public-Hostname-using-account-username/m-p/1807612
Fixes: 388
They can, @Baldrick1  merely moved the topic to the correct board, where it will have better visibility.
willcutforth
Fixes: 113
Hey there @katga I have created a ticket on https://www.plus.net/wizard/?p=view_question&id=232431481
Please reply to that and I will sort it for you.
 Will Cutforth
