rDNS / PTR record change request please
grumbley
I'd like to have the rDNS / PTR record for my static IP changed to NOT include my account username.
Appreciate if someone could pick this up & message me.
Thanks.
Tags (2)
2 REPLIES 2
Tina11192
Fixes: 18
Re: rDNS / PTR record change request please
@grumbley thank you for your recent message, I hope you are well.
I tried calling you to progress the request to remove the username from the reverse DNS / PTR, however, there was no answer.
Just letting you know I have raised this to our NetOps team, I suggest that you check your Plusnet online account at your earliest convenience, as I have sent you a detailed email.
I hope this helps, please let me know if there's anything else I may be able to assist you with.
Cri Ignatti
grumbley
Hi, I responded to the ticket in my Plusnet online account with the requested details,
however I see there is an update saying the ticket has been closed.
The rDNS entry still contains my username, can this be sorted out as soon as possible and
changed from <username>.plus.com to <static-ip>.plus.com.
Thanks.
