ptr record removal
404found
ptr record removal
I should have asked a while ago, but could I get my ptr removed from my static address? Many thanks in advance!
4 REPLIES 4
plusnettony
Fixes: 74
Re: ptr record removal
I've done this for you - check back in 24 hours. Will now show your ip.plus.com
 Tony T
404found
Hi Tony - doesn't look like it's taken I'm afraid 😞
plusnettony
Fixes: 74
I've requested it again, and made a note to check it on Monday.
 Tony T
plusnettony
Fixes: 74
I forgot to ask - can you disconnect/re-connect your router please and let me know.
 Tony T
