email mx
- Everything else
- email mx
email mx
24-02-2014 5:36 PM
I'm just setting up an email server on my Virtual Private Server with Postfix / Dovecot. I am sure I will not get things right first time. So, does anyone know if I change my MX records from the Plusnet email system to my VPS, can I set up an MX record to the old Plusnet email as a backup? If so what what addresses etc?
Message 1 of 6
(813 Views)
5 REPLIES 5
Re: email mx
24-02-2014 5:54 PM
I don't think our domain control system will allow you to do this I'm afraid.
Message 2 of 6
(274 Views)
Re: email mx
24-02-2014 8:39 PM
OK.
As suspected, I did mess it up. No email.
my settings on domain for email
leftfield: blank type: mx pr:i 3 rightfield: my servers ip number
When I went on pingability.com it showed my server name as my server's ip number.my domain name which has really confused me.
I use similar settings for www and e.g. git and they work. Must I use a left field?
thanks
thanks
Message 3 of 6
(274 Views)
Re: email mx
24-02-2014 9:31 PM
You should specify a hostname for a MX record not an IP address.
Cheers,
A.
- http://en.wikipedia.org/wiki/MX_record
Quote The characteristic payload information of an MX record is the fully qualified domain name of a mail host and a preference value. The host name must map directly to one or more address record (A, or AAAA) in the DNS, and must not point to any CNAME records.
Cheers,
A.
Message 4 of 6
(274 Views)
Re: email mx
24-02-2014 11:36 PM
Thanks Avatastic, I misunderstood the Plusnet layout, so I have created an address record, and a mx record. It is taking a long time for this change to propagate so I will see tomorrow.
Message 5 of 6
(274 Views)
Re: email mx
25-02-2014 9:27 AM
Just taken a look and your DNS records seem fine.
Message 6 of 6
(274 Views)
