eMetrics/Statistics causing Javascript error on my sites
- Everything else
- Re: eMetrics/Statistics causing Javascript error o...
26-01-2016 11:37 AM
Hi
eMetrics is causing the following error on my ccgi wesites - 'Uncaught ReferenceError: wiredminds is not defined'
I also notice that my statistics are not working anyway and come up with the following error (see screenshot). Can my analytics/statistics be disabled?
Regards
Regards
Message 1 of 3
(1,398 Views)
2 REPLIES 2
Re: eMetrics/Statistics causing Javascript error on my sites
26-01-2016 5:14 PM
You should be able to turn off the wiredminds pixel code to disable analytics by logging into the control panel. Then open the Web Analytics tool, and once the tool opens go to the Advanced tab. Choose Manage Pixel Code in the menu, then the Disable radio button and OK.
That should stop the WiredMinds Javascript code being added to pages, effectively turning Analytics off.
David
David
David
Message 2 of 3
(542 Views)
04-02-2016 11:12 AM
Many thanks spraxyt, all done. Will try some tests on the site load times now
Message 3 of 3
(542 Views)
- Everything else
