A record for domain without www.
johnmclean
Hello,
I've set up an A record with the left field as "www", but what should I put in the left field to set the A record for when there is no www prefix, I've tried "@" and "." and empty, none have worked.
7 REPLIES 7
bobpullen
Fixes: 290
Re: A record for domain without www.
Type the domain with a qualifying dot at the end, e.g:
domain.tld.
earnshaw1943
Quote from: Bob
domain.tld.
Hi, I hope you don't mind me piggy-backing on this - but my problem is somewhat related.  I want my domain name to point to my static ip - so I suspect all I have to do for the domain hosting settings is:
1.  Make sure I have the option set for "I wish to specify DNS records for hosts under this domain"
2. Configure an additional DNS record as:
stonetheft.co.uk. a     99.99.192.99
This should make all requests point to my static ip and then cascade down to my website published in IIS as stonetheft.co.uk
Is this right?
Cheers
jelv
Fixes: 10
Posting your IP address on a public forum is not a good idea!
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
earnshaw1943
I've changed it - but figured it wouldn't matter as anyone can do an "nslookup" and find out.
dick:quote
jelv
Fixes: 10
Only if they know your username - nobody should have their forum name the same as their Plusnet username.
You can change your forum user name here: http://community.plus.net/forum/index.php?action=profile;u=32957;sa=account
NB That link will only work for this user - for anyone else go to PROFILE, Account Related Settings
bobpullen
Fixes: 290
Quote from: earnshaw1943
Yep, that's right. If you want www requests to point to your web server then you'll also want to set up a CNAME record as follows:
www                CNAME                 stonetheft.co.uk.
earnshaw1943
Thanks very much for your help Bob.
