change a setting on the PlusNet Community
Mark38
Can someone tell how to change the settings so I don't get an email notification everytime someone replies to my topic?
6 REPLIES 6
Penny
Fixes: 9
Re: change a setting on the PlusNet Community
Hi @Mark38
This should work:
(1) Click your name/avatar top right of page, and select 'My Settings' (fifth item down).
(2) Then select 'Subscriptions and Bookmarks' (sixth tab across).
(3) Then select 'Notification Settings' (third tab across, second tab row).
There's a wide range of options you can select from.
There are other routes for getting to the Notification Settings page, but that's what I used when figuring it out.
Regards,
Penny.
* * * joined Force9 on 17/02/98 * * * with PlusNet from 2000 onwards
Superusers are not PlusNet staff but do have a direct line of communication into the business to raise issues, concerns and feedback from the Community.
Mark38
Thank you
Mark38
And do you know how I can close/delete a topic?
Penny
Fixes: 9
As far as I know, only the Moderators - @dvorak , @Mav and @Baldrick1 - have the ability to close (lock) a topic or to remove it altogether.
Fixes: 391
And to follow from @Penny 's comment above, unless the mods decide a topic is not suitable for the forum, or breaks forum rules, they are not removed - they are left in place in case they may help others.
Fixes: 1,495
Both @jab1 and @Penny are correct, this could be a useful topic for others so no need to lock or remove it.
