being moved to Digital Voice
Thorn12
Re: being moved to Digital Voice
@@Baldrick @stuck @corringham
I am in the east midlands so I better get my finger out, but I never do anything in a rush.
So I will get my tea and get round to it later.
So to be sure - I should be able move my landline to Plusnet (hopefully), then when (or before) Full Fibre is connected set up a VoIP with a 3rd party (assuming Plusnet don't come up with anything before that).
Thanx for your input. I'M off for tea now catch up later
corringham
Seasoned Champion
Fixes: 23
BT are "encouraging" most of their customers in the target regions to swap over (there are some exceptions in special cases). I'd expect that once a good number on an exchange have swapped there will be pressure on other providers to move their customers a.s.a.p.
I don't know when Plusnet will "encourage" customers to move (to BT I assume?), but I can't believe they will wait until Dec 25 as that would be sure to create quite a lot of chaos!
Protech
Seasoned Pro
Fixes: 7
@stuck wrote:
@corringham
You mean that even though my phone is being moved from BT to Plusnet, my landline will still die as soon as BT switch my region over to 'Digital Voice'?
I got the impression from the posts in this topic that because my landline will not be with BT at that time, it will continue to work until Plusnet pull the plug on their phone packages.
That's a good question, which only Plusnet or BT can answer.
I would assume that openreach are rolling out "digital voice"  in a given
area to all premises, irrespective of which ISP  supplies the service.
It's up to the ISPs to notify their customers of the upcoming change
You can check out but you can never leave ( easily)
RealAleMadrid
Fixes: 68
@Protech  "I would assume that openreach are rolling out "digital voice"  in a given area to all premises, irrespective of which ISP  supplies the service."  What you assume is completely wrong, Openreach are not doing any digital voice service. They did  in the past have DVA (digital voice access) on FTTP connections but that has been discontinued. It is now up to individual ISPs to offer a  VOIP service or not, some will, some won't. it looks like Plusnet will not have any VOIP phone service.
Protech
Seasoned Pro
Fixes: 7
@RealAleMadrid
My apologies, used the wrong terminology. I should have said that Openreach are rolling out digital phone lines on an area by area basis. My understanding is that is not being done on per ISP basis.
RealAleMadrid
Fixes: 68
@Protech  Please define a digital phone line. There is physically no such thing, a voip phone service can be a run over any connection even with a low data rate. I have had a voip phone service on ADSL and FTTC services. Openreach are removing traditional copper line phone services from all types of connections so not really rolling out but the opposite.😁
Protech
Seasoned Pro
Fixes: 7
I was just using openreach terminology..
Their definition
https://www.openreach.com/upgrading-the-UK-to-digital-phone-lines/for-my-home-or-business
Fixes: 466
There is a very large quantity of personal assumption and pure quesswork being promulgated in this thread.
Returning to the original post and those of a similar ilk. The point that needs to be made is that this is a time of great change in landline telecoms. For most this will be handled by ISPs in a controlled manner.
However, this could turn into a total nightmare for those who have their landline telephone service and broadband contracts with different companies.
To assume that two companies, regardless of whether they are both sub companies of the same organisation, communicate with each other is folly
corringham
Seasoned Champion
Fixes: 23
And also for those that have both broadband and phone with a single company that doesn't offer VoIP.
Fixes: 357
@corringham Why? VoIP services can be supplied by others than ISPs.
Fixes: 558
Yes, but transferring a number to voip whilst retaining other services is problematic.
Fixes: 357
Agreed, @MisterW , However AIUI you can have a 'new' number if you set up an account with a VoIP provider - I know I looked into this a couple of years ago, or longer, but decided it wasn't worth it, as I was using my mobile for all outgoing calls and advising those who had previously used my land line to call my mobile instead, providing it didn't land them with big bills.
These days, I only have two people who call me on the fixed-line phone.
corringham
Seasoned Champion
Fixes: 23
Yes they can, and tech knowledgable people will cope. For non-techies having to sign up to a VoiP provider, sort out a suitable phone and/or ATA will be very daunting - it is a whole lot more intimidating than simply plugging your existing phone into the back of the broadband router.
Fixes: 357
Setting up my first home computer was intimidating 30+ years ago.
corringham
Seasoned Champion
Fixes: 23
And how many of your elderly relatives managed to do the same?
Of course, in those days a computer wasn't a daily essential - unlike a land-line for many elderly relatives these days.
