Domain transfer
Xionone
Domain transfer
Hi, I need to transfer my two domains out of Plus.net to 1and1
1and1 have asked for:
Authorisation code for each domain
Change of IPS tag to:  1AND1  on each domain.
And can you confirm the domains are not 'locked',
Thanks,
Denis.
Tags (1)
5 REPLIES 5
Fixes: 585
Re: Domain transfer
If the domains are .uk , then no Authorisation(EPP) code is required, in fact you can't get one for a .uk domain!
All that's needed is the IPSTAG change
Tags (1)
Xionone
Re: Domain transfer
Can the IPSTAG's for both my domains be changed for transfer to 1and1 please.
Ta,
Denis.
Tags (1)
Fixes: 585
Re: Domain transfer
Hopefully a staff member will be along shortly, and will raise a 'ticket' to which you can reply confirming the domain names and IPSTAG values you require. They will then request the transfer, which can take around 3 working days.
Tags (1)
Fixes: 1,495
Re: Domain transfer
Moderators Note
This topic has been moved from Broadband to Everything Else
Tags (1)
adamwalker
Fixes: 223
Re: Domain transfer
Hi Denis, sure, I just need to ask you to pop a comment on a ticket I've added to your account to authorise it first: https://www.plus.net/wizard/?p=view_question&id=236764341
Please get back to me on here when you have so I can pick it back up for you.
Adam
 Adam Walker
Tags (1)
