Static IP not enabling
Dr_Pepper
Joined Plusnet a few days ago and paid the extra fiver for a static IP. But when I try to active it, this is what I'm presented with:
"Current Status :  You are currently using a dynamic IP address"
I've seen other members with the same problem but thought it best to start my own thread rather than clog up theirs.
Can you sort this please?
Ta very much.
13 REPLIES 13
Fixes: 480
Re: Static IP not enabling
@Dr_Pepper
Welcome to the Plusnet Community Fora.
I presume that you are aware that after it has been activated by Plusnet that you need to reboot your hub to pick it up?
Fixes: 387
What are the first three octets of your public IP?
Dr_Pepper
I am aware of that, yes. But I don't think it is activated yet which is why I wanted someone to give me the thumbs up so I wasn't just rebooting for no reason (if that makes sense).
Dr_Pepper
I'll give you two: 146.199.***.***
Fixes: 585
The definitive test is to check the rDNS using nslookup on your IP. If its dynamic it will say something like <ipaddress-dyn>.plus.net , if static it will show <accountname>.plus.com
Fixes: 387
Thanks, @MisterW  - was trying to remember that option/test.
Dr_Pepper
Very useful. Thank you.
It's definitely dynamic according to your information.
Fixes: 585
@Dr_Pepper you will need to wait for a staff member to come along and sort it. The online static IP requesting process seems to have been broken for a while...
Dr_Pepper
@MisterW
Fine by me. Cheers for the advice.
greygit1
C:\Users\user2>nslookup w.x.y.z
Server: cdns01.plus.net
Address: 212.159.13.49
*** cdns01.plus.net can't find w.x.y.z: Non-existent domain
MatthewWheeler
Fixes: 503
Hi @Dr_Pepper
That should be sorted for you now
If you reboot your router you'll get your new static IP
As of the 1st of January 2026, I no longer work in Plusne,t so I'll be unable to assist you with any queries.
Dr_Pepper
Thanks everyone. All sorted.
greygit1
There appears to be a whole netblock of IP address space allocated to Plusnet which may be lacking some rDNS.
https://www.whois.com/whois/31.185.128.0
w.x.y.z is within that IPv4 netblock.
C:\Users\user2>nslookup 31.185.128.1
*** cdns01.plus.net can't find 31.185.128.1: Non-existent domain
C:\Users\user2>nslookup 31.185.191.254
*** cdns01.plus.net can't find 31.185.191.254: Non-existent domain
(I've checked rDNS of IP addresses within that allocation block and they all appear to have no rDNS).
(sanity check on the nameserver)
C:\Users\user2>nslookup 212.159.13.49
(that appears OK)
Other rDNS checks on other Plusnet allocations have returned (mostly) dyn rDNS.
