WordPress version 2.8.4
- Everything else
- Re: WordPress version 2.8.4
12-09-2009 8:16 PM
Has anyone tried to install the above version on the PAYH server?
I am running a previous version of WordPress and tried to run the automatic upgrade but I was presented with the following:
I would be interested to know if anyone has installed/upgraded this version manually without any problems.
Warning: touch() [function.touch]: SAFE MODE Restriction in effect. The script whose uid is 10230 is not allowed to access /tmp owned by uid 0 in /var/www/vhosts/adios.plushost.co.uk/httpdocs/wp-admin/includes/file.php on line 174
Warning: fileowner() [function.fileowner]: SAFE MODE Restriction in effect. The script whose uid is 10230 is not allowed to access /tmp owned by uid 0 in /var/www/vhosts/adios.plushost.co.uk/httpdocs/wp-admin/includes/file.php on line 628
Warning: fileowner() [function.fileowner]: stat failed for /tmp/1252782631 in /var/www/vhosts/adios.plushost.co.uk/httpdocs/wp-admin/includes/file.php on line 628
Warning: unlink() [function.unlink]: SAFE MODE Restriction in effect. The script whose uid is 10230 is not allowed to access /tmp owned by uid 0 in /var/www/vhosts/adios.plushost.co.uk/httpdocs/wp-admin/includes/file.php on line 630
Message 1 of 7
(2,825 Views)
6 REPLIES 6
12-09-2009 11:58 PM
Hiya
This is because PAYH has PHP Safemode parameter On. to get around this, try to suppress the script from returning warnings by putting the @ sign at the beginning of line 174,628 and 630. the @ sign suppresses any warnings that could have been thrown.
I would be interested in knowing if this has resolved it
![Smiley Smiley](/html/@39650D28FE4EA73A5BA77CFD0A477003/images/emoticons/smiley.gif)
Message 2 of 7
(951 Views)
27-09-2009 11:06 AM
I have managed to install the latest version of Wordpress manually without much hassle. Had to do manual upgrades for all my plugins as well.
It's not too tricky, but a but of a pain.
Message 3 of 7
(951 Views)
27-09-2009 5:46 PM
I don't supposed that it returned the same error messages?
Message 4 of 7
(951 Views)
22-10-2009 12:52 PM
strangely the default install web application wont install:
Yes the MySQL version is 5.something?
I will install this manually now.
Quote •Database required (mysql, version >= 4.0.0) (not available, please check domain or client limits)
Message 5 of 7
(951 Views)
27-10-2009 9:02 PM
Sorry a long time has passed since my original posting.
I ended up upgrading to 2.8.4 manually which was a bit of a pain but it worked successfully. I tried modifying the original script as suggested but it didn't work and I wasn't exactly sure of what I was doing. I tried upgrading automatically from 2.8.4 to 2.8.5 and to my amazement it worked perfectly 🙂 Also I upgraded one of the plugins automatically which also worked.
Has plusnet pressed the magic button here?
Message 6 of 7
(951 Views)
29-10-2009 9:13 PM
Woop Woop! so it's sorted now. I'm not aware of any changes on PAYH platform.
Message 7 of 7
(951 Views)
- Everything else
