Where/how to report general routing problem?
Greg60
Hi Folks, for several days I have been unable to reach the website of major ferry operator ColorLine, www.colorline.com (also exists in multiple national domain versions, .co.uk, .de, .no,  .dk, maybe others).  Everything is fine from my place of work, but not from home using PlusNet.  A traceroute is fine up to a point, so it looks like the destination can't route back to PlusNet; this is an issue PlusNet/BT need to resolve with their peering partners.
Work:
t_perb@dr8:~$ telnet www.colorline.com 80
Trying 195.225.31.64...
Connected to www.colorline.com.
Escape character is '^]'.
GET /
<!DOCTYPE HTML PUBLIC "-//IETF//DTD HTML 2.0//EN">
<html><head>
Home:
greg@shadowII:~$ telnet www.colorline.com 80
telnet: Unable to connect to remote host: Connection timed out
greg@shadowII:~$ traceroute www.colorline.com
traceroute to www.colorline.com (195.225.31.64), 30 hops max, 60 byte packets
1 dsldevice.lan (192.168.1.254) 1.143 ms * *
2 * * *
3 * * *
4 136.hiper04.sheff.dial.plus.net.uk (195.166.143.136) 19.000 ms 19.281 ms 19.266 ms
5 peer7-et-0-0-2.telehouse.ukcore.bt.net (62.172.103.160) 26.344 ms core5-hu0-7-0-26.faraday.ukcore.bt.net (195.99.127.32) 19.240 ms 19.230 ms
6 166-49-214-194.gia.bt.net (166.49.214.194) 21.726 ms 23.884 ms 19.635 ms
7 ldn-b13-link.ip.twelve99.net (62.115.148.100) 19.544 ms * ldn-b3-link.ip.twelve99.net (213.248.71.146) 12.199 ms
8 ldn-bb1-link.ip.twelve99.net (62.115.120.74) 12.416 ms 12.283 ms ldn-bb1-link.ip.twelve99.net (62.115.127.100) 12.271 ms
9 * hbg-bb3-link.ip.twelve99.net (80.91.249.11) 18.986 ms *
10 oso-b1-link.ip.twelve99.net (62.115.112.85) 33.504 ms 34.066 ms 31.559 ms
11 basefarm-ic-306597.ip.twelve99-cust.net (62.115.45.130) 32.993 ms 33.032 ms 35.483 ms
12 * * *
Thanks.
31 REPLIES 31
pjmarsh
Fixes: 24
Re: Where/how to report general routing problem?
Odd.  It's working fine for me on a Plusnet connection, with the traceroute looking the same (from step 7 onwards).
Greg60
Very strange .... ?  I'm experiencing no other problems.  In that case I wonder if my (ie PlusNet's) subnet might be blocked on the destination side; I have from time to time seen complaints about spamming and other unpleasantries originating from the subnet my connection is in.  Do you know where I might take this?
Browsing to www.colorline.com works for me using my Plusnet connection -
Screenshot 2023-08-31 at 13-46-59 Cruise and ferry deals Various crossings Color Line.png
My traceroute is slightly different, but closer to the destination is the same -
$ mtr -r -w -c 10 www.colorline.com
HOST:                                           Loss%   Snt   Last   Avg  Best  Wrst StDev
  1.|-- My_Home_Router                           0.0%    10    0.2   0.2   0.2   0.3   0.0
  2.|-- 250.core.plus.net                        0.0%    10    7.7   6.4   5.8   7.7   0.6
  3.|-- 84.93.253.83                             0.0%    10    6.7   6.5   6.2   6.7   0.2
  4.|-- core1-BE1.colindale.ukcore.bt.net        0.0%    10    6.4   6.4   6.0   6.7   0.2
  5.|-- peer7-et-4-1-1.telehouse.ukcore.bt.net   0.0%    10    6.3   8.4   6.3  22.7   5.0
  6.|-- 166-49-214-194.gia.bt.net                0.0%    10    6.5   6.9   6.5   7.4   0.3
  7.|-- ldn-b3-link.ip.twelve99.net              0.0%    10    7.1   7.1   6.8   7.5   0.2
  8.|-- ldn-bb1-link.ip.twelve99.net             0.0%    10    7.1   7.1   6.9   7.5   0.2
  9.|-- hbg-bb3-link.ip.twelve99.net            50.0%    10   19.5  19.7  19.5  20.0   0.2
 10.|-- oso-b1-link.ip.twelve99.net              0.0%    10   31.8  31.9  31.7  32.3   0.2
 11.|-- basefarm-ic-306597.ip.twelve99-cust.net  0.0%    10   32.0  32.0  31.6  32.3   0.2
 12.|-- ? ? ?                                  100.0%    10    0.0   0.0   0.0   0.0   0.0
pjmarsh
Fixes: 24
A couple of possible “fixes” if that’s the case. 1) would be to turn your hub off for a while to try and get a different IP address and see if that helps. 2) would be to get a static IP address, though that has a one-off £5 charge. You should be able to do that in the members centre but there has been some talk about it being broken and if so a member of staff would need to do it.
Greg60
Thanks, yes, but turning off isn't an option during the day (working remotely).  I can maybe try that over the weekend; or maybe use a trial VPN ... but this is obviously not a problem of my making, or anything I can solve except by luck or extra expenditure.  I should be able to report this to PlusNet.
Greg60
@Anonymous thanks, yes, I've just tried with my mobile; no connection if using WiFi, fine if using mobile data.
Fixes: 386
Just a thought - if you are using a VPN, is that specific site picking that up and deciding it doesn't like it?
Greg60
@jab1 I'm not using a VPN, but doing so would probably be a workaround.
Fixes: 386
OK - I just thought if you were remote working, you would be possibly be using one to connect to your office/place of work.
Greg60
Ahh, I see; I'm using an ssh tunnel to reach my work site, so that's a separate affair, I have normal connectivity from my home network.  Everything was fine last week, this is something that has happened since then.
Fixes: 386
No problem - it was just a thought .
@Greg60
It is worth noting that host 195.225.31.64 does not respond to pings so trace route will not really a good test for routing in this case.
Pinging 195.225.31.64 with 32 bytes of data:
Request timed out.
telnet has failed due to a 'Connection time out'
last hop from trace route is
I pinged 62.115.45.130 with this reply from 62.115.45.130: bytes=32 time=36ms TTL=54
So the attempt to connect is happening, it's just timing out.
You can test what ports are open using this site https://www.yougetsignal.com/tools/open-ports/
Have you tried telnet on port 443 (https)
Dan
Edit: when you attempt to telnet run netstat so see what the connection state is look for something line this
TCP    <your device ip>   195.225.31.64:443      ESTABLISHED
Greg60
Hi Dan, the traceroute is just to see there's connectivity at least some part of the way; the server will be behind a firewall somewhere on the other side of the last visible router.  There's connection from other places, but not my home broadband; I have observed no other problems from my home broadband, and traceroute shows generally god outward connectivity towards the target, so the reasonable conclusion is there's a problem routing back from the server or data centre.  TCP state is SYN_SENT, as I would expect.
tcp 0 1 shadowII.lan:33826 web.colorline.ba:telnet SYN_SENT
It always best gather facts. I agree the SYN_SENT does not look good.
As previously mentioned, either drop your connection for a while or hopefully a static IP might help
Dan.
