Webspace usage missing
- Everything else
- Re: Webspace usage missing
- « Previous
- 1
- 2
- Next »
23-01-2015 12:53 PM
23-01-2015 1:44 PM
23-01-2015 3:23 PM
23-01-2015 10:24 PM
31-01-2015 7:36 PM
04-02-2015 4:09 PM
I have 100Mb website space allocated and this was showing 87Mb used with just 13Mb free. But my web site has just 59 Mb of files loaded, and PlusNet checked and confirmed this to be the case.
After "curing" the problem it reverted to showing 87 Mb used.
Since then it has again gone back to showing 0% used and 100% free !!
PlusNet seem to have given up on the matter and just said that I will be notified if I exceed my allowance.
When I asked about the difference between 87 Mb and my 59Mb of files loaded I was told that the extra 28 Mb were being taken up by their Web Stats.
Rather surprised to find that my web stats are taking up around half the space needed by my 70 page site, including several hundred photos / slide shows. Can this really be correct ?
Only solution offered is that I disable my Web Stats completely, which should apparently recover more space for expansion of my site.
But will it - or will I still find that my stats show Nil space used ? And then be without their stats (though I do have Google Analytics).
10-12-2015 4:34 PM
10-12-2015 9:33 PM
Not sure it's right, though: I have a copy on my HDD which says it's about 150MB, whereas Webspace Usage says it's 206MB.
The last time I had this sorted out (a few years ago now), I was told that the difference was down to old log files, and that these wouldn't count towards my usage. Is this right? If not, is it possible to remove the log files (since I never use them)?
10-12-2015 9:43 PM
11-12-2015 12:38 PM
When I checked a few minutes ago my webspace usage was reported as "0% used, 100% free" instead of something like "60% used, 40% free"
11-12-2015 9:22 PM
Quote from: Bob If you've raw logging enabled then the log archives are all in the /logs directory on your webspace.
That dir appears to be empty.
I've gone through all I have on the server and can only make it add up to about 148Mb. What could be taking the other 58Mb?
15-12-2015 8:53 PM
16-12-2015 2:30 PM
18-09-2016 9:12 PM
Whatever it was nearly a year ago is back. My webspace usage is being reported as zero but I know it to be close to 200MB.
- « Previous
- 1
- 2
- Next »
- Everything else
