Web Site Archived!
- Everything else
- Re: Web Site Archived!
Web Site Archived!
13-08-2014 9:59 AM
www.holywellhousepublishing.co.uk
What is my band width allowance?
Why am I so popular all of a sudden!
How do I find out if pages are being hot linked?
Or is there another explanation?
And why does Plusnet cut you off without offering any advice or help in solving the problem?
Bill
[Moderator's note by Dick(Strat) Caps edited as per forum rule.
Re: WEB SITE ARCHIVED!
13-08-2014 11:44 AM
Your bandwidth allowance is 100MB per day.
It is not easy for you to establish who is linking to your site without a webstats application. I have added our own webstats solution to your account which will take up to 24 hours to activate. When it's ready, the feature will be accessible via the 'Standard Webspace' section of the Member Centre.
Another possibility is that you have uploaded and subsequently downloaded a large file (or files) from your webspace that has taken you over your bandwidth quota.
Our automated process favours the immediate protection of the platform over any sort of advanced notice. I'm sorry if it's caused inconvenience. You should have received an email though?
I have unarchived your site so it should be accessible again.
13-08-2014 12:06 PM
Thanks for the rapid response.
I do have Web Free Stats which has become totally unreliable.
And does not appear to show most "popular" pages.
And could never find how to "switch on" web stats at Plusnet.
It's quite alarming to find ones web site vanishes - without any ADVANCE warning.
Just an auto er-mail. No help, advice or whatever.
But I do appreciate YOU coming to the rescue.
Shall try & find the cause ...
Bill
13-08-2014 12:49 PM
If they do that might explain my going over my 100 Mgb daily allowance.
But if they don't then I am at a loss to understand how this could happen.
Bill
13-08-2014 2:08 PM
13-08-2014 3:00 PM
If you have search engines indexing the page / downloading the .pdf etc you could soon end up running out of steam.
On the Hard Fought Ship page, the book cover is nearly 1Mb on its own - added to the other pictures on that page and less than 100 page hits on that page in 24 hours would kill your bandwidth allowance.
Hope that helps
Dom
14-08-2014 11:06 AM
THE BOOK COVER ON FRONT PAGE
File size is 127 Kb - so a long way from being a Mgb
But I have to admit to nor knowing I had a limit on band width.
I thought I was only limited to 100 Mgb for the size of my site.
And as a result kept an eye on that.
But ignored bandwidth.
It may take a while to check this out.
And also to decide what to do.
Am told it's foolish to to host a web site with one's ISP - as it tends to tie you down if you need to change.
Would all of you agree?
And does Plusnet have other clients who do both?
Have web space AND have Plusnet as ther ISP?
Or am I the only one.
Please let me know.
Bill
14-08-2014 3:10 PM
377.59 KB (386,649 bytes)
14-08-2014 3:22 PM
Not sure if you removed the other large image as I can't spot it to resample but I've attached a lower resolution image for your first page if it you want to use it.
Dom
14-08-2014 3:26 PM
http://www.holywellhousepublishing.co.uk/webimages/xxx.jpg
889.84 KB (911,200 bytes)
If someone viewed that 100 times in a day it could push you over your limit.
Resampled it reduces to 46K - that is around 1/20th of the size (I've attached the resampled image)
These seem the main offenders.
14-08-2014 11:03 PM
And have just sent it to the server by FileZila.
Please check and let me know if the one on the server is NOW only 127 kb.
It's possible I may have reduced its size a year or two - or three - back.
But forgot to ftp the small version to the server.
Please let me know.
Bill
14-08-2014 11:28 PM
The 40 years at sea cover on the front page is still saving through IE11 (and Firefox) as a 377kb (ish) file and the HFScoverBIG.jpg is still around 900K in size
I'm being moaned at by the wife that it is time for bed now otherwise I'd investigate a bit more but hopefully another member / staff can verify this.
15-08-2014 9:04 AM
And apologies to your wife.
It seems that when I reduced the file size I (slightly) changed the file name.
I changed BIG to Big.
And as a result since I did not change the link it continued to point at BIG - which as you pointed out is VERY BIG!
I have changed that now.
But still need to look at the other cover image.
It has an ISBN (numeric) as the file name.
And I can't at present LOCATE IT!
Bill
15-08-2014 10:33 AM
It might be worth renaming or removing it from your site just in case any historical searches or links still access it and suck your bandwidth
I remember when a post of mine went viral (a homebuilt washing machine running Windows) the site it was posted on experienced a hundred times the the traffic overnight and it almost killed the host that the pictures were hosted on
15-08-2014 10:47 AM
But shall delete Big and just leave BIG.
Still puzzled as to whether when I signed up with Plusnet they had a limit on band width.
Or just the limit on the size of web site.
Until now I thought the only restraint was on the size of the web site & I am still well within that.
Do you pay for web hosting or get it for free?
And if you pay what attracted you to Plusnet?
I joined because they had san excellent reputation as an ISP.
And then when I needed web space found they provided it for free.
But they were independent then - not just part of BT - and I have cable under the pavement outside our terraced house.
But, can't stand the hassle of making the move ...
Bill
- Everything else
