VPN Not working
- Everything else
- VPN Not working
VPN Not working
17-02-2020 9:04 PM
Hello,
I have an issue connecting to my works vpn. It is incredibly slow and does not allow me to use webpages or DB services.
I am currently using Pulse VPN. I have tried clamping and forwarding. I was going to try changing MTU but this is not supported on the stock Plusnet router.
All other non VPN sites work fine.
I was hoping to try the suggestion on the URL:
https://community.plus.net/t5/Everything-else/VPN-not-working/m-p/1556716#M19665
Does anyone have any suggestions?
Re: VPN Not working
20-02-2020 8:40 PM
Hi @alexisesmee, I'm sorry that you're having issues with your VPN,
If you haven't already, can you please try the steps mentioned on this thread here; I would also recommend speaking with your works IT department about this and the issues experienced.
Let us know how you get on.
Re: VPN Not working
21-02-2020 7:20 AM
Update to follow.
Re: VPN Not working
25-02-2020 1:00 PM
