Update PTR / Reverse DNS
mikeyue
I have a domain (yue.org.uk) being hosted by 123-reg , is it possible to update the PTR, so reverse for my static will resolve yue.org.uk instead of michaelyue.plus.com
thanks
Mike
3 REPLIES 3
Fixes: 585
Re: Update PTR / Reverse DNS
@mikeyue yes, it is. One of the staff will pick up this thread and process the request. It may take a day or two though.
In preparation , make sure you have an A record pointing your domain to your static IP as that will be checked before setting the rDNS
Windings
Fixes: 14
@mikeyue Hi there,
Picked this up and raised the task for you today.
As @MisterW Mentioned, this can take a couple of working days. Usual lead times are 3-5 working days but can be sorted sooner depending on the workload the netops team have.
All the best
Joe Elliott
plusnettony
Fixes: 78
As luck would have it, I'm on that server now, so I've made the change.
 Tony T
