Securing an old number
mystreet1
Seasoned Pro
Fixes: 7
I want to see if I can obtain my grandad number. The number has not been in service for about 15 years.
A&A stated that only 30 days.
Anyone know how and with whom I could try and get it with.
Was a member for years, but moved from PN fttc to fttp from an AltNet. Getting 940Mb up and down. Happy to stay on here and try to help others. 
1 REPLY 1
outcast
Aspiring Champion
Fixes: 19
Re: Securing an old number
According to Grok -
As a consumer looking for a specific UK landline phone number, you can take practical steps to check its availability and potentially acquire it. UK landline numbers are tied to geographic area codes (e.g., 020 for London) and managed by Ofcom, but allocated through communications providers (CPs) like BT, Virgin Media, or VoIP services. Since you're targeting a specific number, here’s how to proceed:
1. Contact Major UK Landline Providers
Landline providers can check if a specific number is available in their inventory or recyclable (e.g., after a period of inactivity, typically 6–12 months).
  • Major Providers:
    • BT: Call 0800 800 150 or visit a BT shop. Provide the full number (e.g., +44 20 1234 5678) and ask if it’s available for assignment. They manage many geographic numbers.
    • Virgin Media: Contact 0345 454 1111 or use their online chat. They can check availability for your area code.
    • TalkTalk: Call 0345 172 0088 to inquire about specific numbers in your region.
    • Smaller Providers: Local ISPs or VoIP providers like Vonage or Gamma Telecom may offer more flexibility for specific numbers.
  • What to Ask: Specify the exact number and your postcode (landlines are location-specific). If it’s not in use, they may assign it or suggest similar numbers. If it’s active, they’ll inform you it’s unavailable.
Note: Providers don’t publicly list individual numbers due to privacy, so direct contact is key. Be prepared for setup fees (typically £10–£50) if the number is available.
2. Use VoIP Services for Greater Flexibility
VoIP providers often allow consumers to search for and purchase specific UK landline numbers, especially for virtual use (not tied to a physical line). These are ideal if you want the number for business or personal use without a traditional landline.
  • Recommended Services:
    • KrispCall: Use their Phone Number Availability Checker (free). Sign up, enter the number with the +44 prefix, and check its status. If available, you can buy it instantly (starts at ~£5/month).
    • Calilio: Offers a free checker tool. Input the number under “Purchase Number” in their dashboard to verify availability. Supports UK landlines and allows purchase if free.
    • TextMagic: Their validator checks if a landline is active or disconnected. If disconnected, it’s likely available via their purchase platform.
    • Twilio: Sign up and use their number lookup tool to check availability. You’ll need to provide ID for regulatory compliance, but they support UK geographic numbers.
  • Process: Search the number online via their platform. If it’s unallocated, you can buy it for use with VoIP apps or forwarding. Costs range from £5–£20/month, depending on features.
Advantage: VoIP services are more likely to have specific numbers available, especially for virtual landlines, and aren’t always tied to your physical location.
3. Check Number Status with Validation Tools
Free online tools can help confirm if the landline is currently active, giving you a clue about its availability.
  • HLR Lookup (hlrlookup.com): While mainly for mobiles, some services support landlines. Enter the number to see if it’s disconnected (potentially available) or active. Free credits available.
  • IPQualityScore Phone Validator: Free tool to check if the number is active, disconnected, or invalid. Disconnected numbers may be recyclable soon.
  • Who-called.co.uk: Enter the number to see if it’s linked to recent activity (e.g., spam reports). No activity suggests it might be free.
  • Data8.co.uk: Offers landline validation, showing carrier and status. If unassigned, contact the listed carrier to inquire.
How to Use: Input the number with +44 and area code. If the tool shows it’s disconnected or invalid, it’s likely available through a provider. If active, it’s in use and not purchasable.
4. Explore Ofcom’s Numbering Data (Manual Check)
Ofcom’s National Telephone Numbering Plan data can indicate if a number is allocated, but it’s less consumer-friendly and requires effort.
  • Visit Ofcom’s numbering data page (ofcom.org.uk/phones-and-broadband/phone-numbers/numbering-data).
  • Download the latest CSV/XML files (updated Wednesdays) listing allocated and available ranges.
  • Search for the specific number or its range (e.g., 020 1234 XXXX). If not listed as allocated, it’s potentially available via a CP.
  • Challenge: Files list blocks (e.g., 020 1234 0000–9999), not individual numbers, so you’ll need to contact a provider to confirm the exact number.
  • Contact Ofcom: Call 0300 123 3000 for guidance if you’re unsure how to interpret the data. They’ll direct you to a CP.
5. Consider Vanity or Memorable Numbers
If the specific number is a vanity number (e.g., 020 1234 5678), it might be held by a provider or Ofcom for premium sale.
  • Check with providers like BT or VoIP services for memorable number options.
  • Ofcom occasionally auctions premium numbers—monitor their site for announcements.
  • Costs for vanity numbers can be higher (e.g., £50–£500 one-time or higher monthly fees).
Practical Tips
  • Verify the Area Code: Ensure the number’s area code matches your location (e.g., 0161 for Manchester). Providers won’t assign mismatched geographic numbers for landlines.
  • Check Recycling Status: If the number was recently disconnected, ask the provider if it’s in the recycling pool (typically 6–12 months before reassignment).
  • Act Quickly: Available numbers can be snapped up fast, especially desirable ones.
  • Costs: Expect setup fees (£10–£50) and monthly charges (£5–£20 for VoIP, higher for physical lines). Vanity numbers cost more.
  • If Unavailable: Ask for similar numbers (e.g., same digits with a different ending) or wait for recycling. Providers can notify you if it becomes available.
Recommended First Step
Start with a VoIP provider like KrispCall or Calilio. Use their free availability checker to input the number. It’s quick, consumer-friendly, and lets you purchase directly if available. If you prefer a traditional landline, call BT or Virgin Media with the number and your postcode to check.
