Unable to send emails
longshanks67
I use an android 12 Tablet and have had intermittent problem  sending email with the occasional message telling me  that my IP  address is poor. I use webmail all the time, this does not happen on my laptop using Thunderbird as the client. I have read other emails on the same subject but those did not offer advice that I could use, Superuser comment was very informative , another solution was to turn off mobile data for a while then turn it back on this is not for me  as I don't use mobile data. I would appreciate some advice on how to cure this problem,
I use Nord VPN .
many thanks
14 REPLIES 14
Fixes: 385
Re: Unable to send emails
Turn off the VPN on the phone - one or more of the IP's this  is routing through has a bad reputation. Why do you use a VPN?
longshanks67
hi,
Not a phone and I use a VPN for better security and streaming.
Fixes: 385
OK, sorry, I misread your initial post -  substitute tablet for phone in my reply. A VPN does not offer 'better security' - especially for a home user - and, as you have discovered, it can inhibit the proper functioning of your connection.
Fixes: 581
@longshanks67 and I use a VPN for better security and streaming
problem is that other people use VPN's for more dubious reasons, and so the IP addresses allocated by the VPN servers get poor IP reputations.
Try disconnecting the VPN and then see if you can send email.
longshanks67
Thanks for the info very useful, my set up is a two router in piggy back the secondary is dd wrt with
solely for VPN use, at the moment the tablet I use is using the VPN network I will switch back to my primary network and see if I get an improvement.
many thanks
longshanks
longshanks67
Hello Mr.W
Again many thanks for the info and advice, I disconnected from my VPN and reconnected to my  primary account network and this email problem went away and now back to normal on my android tablet. What I do find a bit baffling is when I use my laptop which again using my VPN but with a different email manager ( Thunderbird )  this email.problem did not happen so I'm still scratching my head.
regards
Fixes: 581
@longshanks67 are you absolutely sure your laptop is sending via the same VPN connection as the tablet ?
Try using https://whatismyipaddress.com/ on both the tablet and laptop and check that you're seeing the same public IP on both
longshanks67
hi.
Yes I'm absolutely sure my laptop is using the VPN, baffling isn't it? although I mainly use my tablet to handle my emails, I do use my laptop occasionally to receive and also send the odd Emails and as previously said that works ok albeit that uses a different email client.
Fixes: 581
Shouldnt make any difference as long as the outgoing server settings are the same , and they both use authentication with the same credentials.
A thought, Are they both set for TLS using port 587 ?
longshanks67
Apologies this is incorrect rather than rely on my fading memory I have now done a proper check and no my tablet and my laptop have different IP addresses
regards.
SIfox211
I too have this problem, sending either via Thunderbird on my Win10 desktop or from the default mail client on my iPhone.  Turning off VPN (or switching to one of Nord VPN's overseas servers) immediately fixes the problem.
I have VPN because security in the current climate is vital and reducing security is not an option.
Since the problem appears to be linked to a Nord VPN server being blacklisted, how do I get it whitelisted?
Fixes: 385
You need to talk to Nord.
SIfox211
Thanks - I did and they suggested talking to PlusNet to get it whitelisted... 😉   Guess I'll need to give them a call.
Fixes: 385
The owner of the troublesome IP (Nord, in this case) is the one who should be taking the action.
