Unable to login to the Plesk Control Panel
keppy2008
After entering https://plesk-host02.net:xxxx ;   etc i get the PLEASE WAITING LOADING message. Anyone help or advise please  THANKS  , Ken
12 REPLIES 12
jelv
Fixes: 10
Re: Unable to login to the Plesk Control Panel
I wonder if it is something to do with this: http://usertools.plus.net/status/archive/1231951632.htm
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
keppy2008
Thanks  Jelv for bringing that info to my notice.
I had the same prob last evening but did not report it..  I will hang fire for the time  being because it isnt time important at the moment.
Anyone else having the same problem ?
Ken
Gabe
Quote from: keppy2008
Yes. Wonder how long "Early tomorrow morning" will continue. "About 1 hour"?
Gabe
spraxyt
Aspiring Legend
Fixes: 75
Not directly relevant but logging into my control panel on plesk-host03 works fine. Operations seem exceptionally nippy too.
David
David
bobpullen
Fixes: 290
I'm able to login to https://plesk-host02.plus.net:8443 - Are people still having problems?
Gabe
Quote from: Bob
Yes: on plesk-host03. No error message, it just recycles the login.
Gabe
Kev_Mawson
Hi
It is showing on the logs that you are logging in to your control panel, can you try deleting your cookies and try again.
spraxyt
Aspiring Legend
Fixes: 75
That looks like a cookie clash (PHPSESSID I think), with other *.plus.net sessions. Deleting all *.plus.net cookies then restarting the browser and trying again usually fixes this.
David
David
jelv
Fixes: 10
Have you been on to the Usertools/Usergroup recently? It seems to be from there that the cookie clash comes from.
Given that this problem has been known about for some time (http://community.plus.net/forum/index.php/topic,70133.0.html) I wonder when something will be done about it.
Gabe
Thanks Kev. Thanks David.
Quote from: jelv
I have. It does.
If I may be allowed: Doh!
Gabe
spraxyt
Aspiring Legend
Fixes: 75
I think it also occurs if one has accounts on two different Plesk hosts and log into both control panels at the same time.
David
keppy2008
Just to say i can get access now.
Thanks to all who helped in any way .
Ken
