Unable to log into member services
tdliedtke
When I try and access the accounts or support section of the Plusnet site I get this in Firefox:
Secure Connection Failed
An error occurred during a connection to www.plus.net. PR_CONNECT_RESET_ERROR
Error code: PR_CONNECT_RESET_ERROR
    The page you are trying to view cannot be shown because the authenticity of the received data could not be verified.
    Please contact the web site owners to inform them of this problem.
Learn more…
and this in Edge:
Hmmm… can't reach this page
The connection was reset.
Try:
ERR_CONNECTION_RESET
19 REPLIES 19
SammyM
Fixes: 101
Re: Unable to log into member services
Hiya @tdliedtke
I'm really sorry this is happening, have you tried it on a none secure connection page? or alternative browser?
 Sammy M - Sheffield Team
tdliedtke
I can get to the community pages fine. The same happens with Edge and Chrome.However, I have found that the issue only happens when I am using my Nord VPN connection.
Fixes: 357
Probably because the IP is recognised as non-UK, and Plusnet only operates in the UK?
tdliedtke
I am connecting to the UK servers. Other geo specific services like BBC iPlayer are working fine. Access to Plusnet community (like this forum) are working fine too.
Fixes: 357
But those 'servers' will see a non-UK IP, and in the case of the Plusnet ones, they will reject the request, as they will see an attempt by a non-authorised connection. TBH, I'm surprised iPlayer works, but can't comment as I don't use it.
EDIT: Actually, even if you get a 'UK' address from NORD, it will not be one on the Plusnet range, so for obvious security reasons, will still be rejected - still seen as not a valid IP, for the purposes of accessing those specific functions.
tdliedtke
Thank you for your explanation.
I will just have to terminate my VPN when I need to access these services. This issue however has only come up fairly recently.
Fixes: 357
Purely out of curiosity, why do you use a VPN for normal surfing?
Fixes: 139
@jab1
I am not user you're correct you need a plusnet IP address to use the members centre, I can use Vodafone mobile data and Windscribe VPN with no issues
Fixes: 357
OK, @Dan_the_Van . Thinking about this more logically, I am slightly wrong - apologies. I should have realised that i (on a Zen IP) can access them, I suspect it is because the NORD VPN will be routing outside the UK.
Fixes: 139
@jab1
Everything is hidden behind the VPN public IP address, that's the point of using the likes of nordVPN or alike.
Fixes: 357
I know that, Dan, but, and I am only surmising here, the routing takes the connection outside the UK, and maybe security has been upgraded, so that connections via a 'foreign' route are rejected?
Fixes: 139
It pays not to surmise when it comes to networks and how stuff connects.
Fixes: 357
OK, but I think I may be (possibly) half right. May try myself later, if I remember.
tdliedtke
Well, I checked again this morning and all is back to normal. I can now access the account area etc again with my VPN up. As far as I am aware nothing has changed at my end.
