Madasafish/Freenetname Transfer Out - IPSTAG
allancmcd
I have searched the forum and found some really helpful posts on this but the bit  I am stuck at is changing the IPSTAG - I can't seem to log in anywhere or find a control panel to change my IPSTAG to MYTHIC-BEASTS
I know my account details are still active as I can log in to the old Madasafish site but there is no functionality in there now, and I can't seem to log in to the main PlusNet site at all.
Could someone kindly point me in the right direction. Thanks all.
13 REPLIES 13
Fixes: 580
Re: Madasafish/Freenetname Transfer Out - IPSTAG
That's because there isnt one! It's done internally via a request to Netops to change the IPSTAG. You can either wait for a Plusnet Help team member to spot this thread and raise a 'ticket' to which you can reply with the details and then the request can be raised, OR you could try calling customer support and requesting the change. Problem is that domain hosting is a legacy facility (especially Madasafish/Freenetname accounts) and getting someone in 1st line support who knows about it is probably a bit hit & miss.
allancmcd
That explains a lot, thanks. I'll try giving them a call at lunchtime. Hopefully I'll get someone who knows about their legacy systems
Fixes: 479
Moderator's Note
This topic has been moved from Email to Everything Else
allancmcd
Hi, not sure why this was moved - it was specifically about email migration? Thanks
allancmcd
Sorry I realise I could have been clearer in my original post. This is for moving an email account
willcutforth
Fixes: 113
Hey there @allancmcd I have created a ticket on the account. Please reply to the ticket on https://secure.madasafish.com/myaccountdx/summary/
 Will Cutforth
allancmcd
Got a really helpful support agent,  but he didn't have any real idea how to proceed - they are going to call back - watch this space, I'll detail any steps they need to hopefully help others in the future
Fixes: 246
Did you reply to the ticket?  That will negate the need for the support agent to call back.
willcutforth
Fixes: 113
I agree @Townman if you reply to it @allancmcd I can sort it for you.
 Will Cutforth
allancmcd
Yes, William posted as I was on to the support line. Have responded on the madasafish portal.
allancmcd
Thanks Will. have replied on the portal
willcutforth
Fixes: 113
Awesome, thanks Allan. I have sent that over now so it should be done within the next 3 days. Do you need me to do anything else at the minute?
 Will Cutforth
allancmcd
Hi Will,
Thanks that should be everything. I did get a return call from Customer support as well. I think he was struggling to find anything within the systems he had access to make the change, so thanks again for stepping in.
