Tv connection
Frang
Tv connection
I recently moved house and had Plusnet full fibre installed. Everything is working fine except the Wi-Fi connection to the tv. I can’t get iPlayer, Netflix etc. This message comes up: No network cable detected. To connect to your wired network, insert a network cable into the tv.
I have no idea what they mean!
15 REPLIES 15
Fixes: 392
Re: Tv connection
@Frang How do receive your TV feed - direct from an ariel, or via a set-top box of some variety?
Re: Tv connection
Connect an ethernet cable between the TV and the router.
Fixes: 392
Re: Tv connection
Or set up a wireless connection - I assume most modern TVs have that option in their settings somewhere?
Frang
Re: Tv connection
The router and tv are in different rooms though.
Frang
Re: Tv connection
No idea how to do that!
Fixes: 392
Re: Tv connection
I probably won't look until tomorrow, but what make and model is your TV?
outcast
Aspiring Champion
Fixes: 19
Re: Tv connection
@jab1  is it your bedtime already ? ,  you're getting confused between a TV and a washing machine ?
An  aerial  is something you mount on the roof -
Frang
Re: Tv connection
It’s a Samsung
Frang
Re: Tv connection
From an aerial
Fixes: 392
Re: Tv connection
Very funny, @outcast  - maybe.
Sorry @Frang  - how do you receive your TV feed - direct from an aerial or via a set top box?
Fixes: 392
Re: Tv connection
A Samsung - OK, but what exact model, so I can find the manual?
How did you have it set up previously?
outcast
Aspiring Champion
Fixes: 19
Re: Tv connection
Fixes: 392
Re: Tv connection
Thanks, @outcast - you have probably stopped a couple more hairs going grey.
This topic is now all yours - if the OP needs more assistance.
outcast
Aspiring Champion
Fixes: 19
Re: Tv connection
@jab1 wrote:
... you have probably stopped a couple more hairs going grey.
@jab1  Did you know  ariel  is gentle on colours and stops natural fibres fading to grey ?  🤣
