Text Support Not Working
- Everything else
- Re: Text Support Not Working
- « Previous
- 1
- 2
- Next »
yesterday
Google is forever useful for such questions…
Contact Classification (Android)
- Cause: In some contact apps, if a phone number is accidentally saved or classified under "Home," "Work," or "Landline" instead of "Mobile", the device may block outgoing SMS.
There are others … take a look.
yesterday
@KevinH1980
Just reading your words about : 40 or so failed texts
an hour ago - last edited 59 minutes ago
@KevinH1980 wrote:
I have found a solution, or so it seems.
I phoned the 0330 number and selected option 1 for a fault. The automated service then sent me a text. This arrived in the same conversation as the 40 or so failed texts. Texts are now flowing properly between me ans plusnet.
Absolutely bizarre.
I don't understand why you didn't try that first, considering that I had exactly the same solution back in April in message #9. A thread that you commented on...
- « Previous
- 1
- 2
- Next »
- Everything else
