Switch Hosting
- Everything else
- Switch Hosting
Switch Hosting
2 weeks ago
My website does not show now and I have looked into moving to another hosting site. They have asked if Plusnet if they can change the nameservers. Can you help.
Re: Switch Hosting
2 weeks ago
Can someone tell me why my website I've had since 1999 has been turned off. This is all i see:
| Name | Last modified | Size | Description | |
| htdocs/ | 2025-10-14 15:58 | - | ||
Re: Switch Hosting
2 weeks ago
@Taxisnooker
Your website appears to have a Greenby IP address, have you raised a Greenby support ticket ?
> nslookup www.taxisnooker.co.uk
Server: cache1.service.virginmedia.net
Address: 194.168.4.100
Non-authoritative answer:
Address: 91.204.210.16 <<<<---- Greenby IP range.
Aliases: www.taxisnooker.co.uk
www.users.freenetname.co.uk
Re: Switch Hosting
2 weeks ago
I can't get access to Greenby. It doesn't recognize my details.
Re: Switch Hosting
2 weeks ago
Re: Switch Hosting
2 weeks ago
what are you using as credentials ? it should recognise your Plusnet account name & password , the same as you use to access the Plusnet portal.
