Switch Hosting
Taxisnooker
Switch Hosting
My website does not show now and I have looked into moving to another hosting site. They have asked if Plusnet if they can change the nameservers. Can you help.
5 REPLIES 5
Taxisnooker
Re: Switch Hosting
Can someone tell me why my website I've had since 1999 has been turned off. This is all i see:
[ICO] Name Last modified Size Description
[DIR] htdocs/ 2025-10-14 15:58 -
Apache/2.4.58 (Ubuntu) Server at www.**********.co.uk Port 80
PhilipHeyes
Seasoned Champion
Fixes: 27
Re: Switch Hosting
@Taxisnooker
Your website appears to have a Greenby IP address, have you raised a Greenby support ticket ?
> nslookup www.taxisnooker.co.uk
Server: cache1.service.virginmedia.net
Address: 194.168.4.100
Non-authoritative answer:
Address: 91.204.210.16            <<<<---- Greenby IP range.
Aliases: www.taxisnooker.co.uk
www.users.freenetname.co.uk
Taxisnooker
Re: Switch Hosting
I can't get access to Greenby. It doesn't recognize my details.
mystreet1
Seasoned Pro
Fixes: 7
Re: Switch Hosting
Just viewed your site ok, apart from the security certificate error
Was a member for years, but moved from PN fttc to fttp from an AltNet. Getting 940Mb up and down. Happy to stay on here and try to help others. 
Fixes: 585
Re: Switch Hosting
@Taxisnooker
what are you using as credentials ? it should recognise your Plusnet account name & password , the same as you use to access the Plusnet portal.
