Static IP request
greyt1
Static IP request
Hoping a staff member can process a static IP request for me.
Tried through the member portal but as is well documented - this doesn't work.
I opened ticket 239178808  yesterday and was told to wait 24 hours since everything is working normally and the static IP is queued for activation. 24 hours later and nothing has changed. I rebooted my router just now to be 100% certain and am still getting a dynamic IP.
Thanks!
11 REPLIES 11
willcutforth
Fixes: 113
Re: Static IP request
Hey there @greyt1 it should all be sorted for you now Smiley Let me know if not.
 Will Cutforth
greyt1
Wow, that was quick!
Static IP assigned but the reverse DNS record shows a different user name. Not the end of the world but do you know if that gets replaced automatically over time?
Thanks for processing the static IP request so quickly.
greyt1
One more question :-
I see multiple references to a Plusnet managed firewall. Is this active and if so how can I get this disabled?
There is some Plusnet documentation stating to go to connection settings, but there is no firewall link here.
I tried a direct link that has been posted previously of https://www.plus.net/member-centre/broadband/firewall but the page doesn't complete loading.
I have some inbound ports working (443 / 80) etc, but I need UDP 4569 and ideally port 88 (but if I know what ports the firewall isn't blocking then I can move this service to another port)
RealAleMadrid
Fixes: 68
@greyt1  Different username sounds totally wrong to me, you need Plusnet to look at that and fix it. @willcutforth
@greyt1
New accounts may not have the option for the account firewall as it is no longer available, so for now image it's turned off.
https://www.plus.net/help/broadband/about-plusnets-broadband-firewall/ for details on the firewall
HTH
willcutforth
Fixes: 113
@greyt1 just to get the full picture, is it your username or someone else's?
 Will Cutforth
greyt1
I don't mind posting the full details. The reverse DNS is currently simonchester.plus.com
Not my user ID or my name 🙂
Fixes: 479
@greyt1
If you have a Plusnet firewall you will find all the controls here :https://www.plus.net/member-centre/broadband/firewall
greyt1
This was the link I posted earlier in the thread. This doesnt appear to work.
It briefly shows a page stating it is loading config (see attached) and then the screen goes blank (just a totally white page).
Tested with Chrome (Windows), Edge (Windows), and Safari (Ipad)
Fixes: 479
@greyt1
If this is a newish account I would assume that your service does not include  the Plusnet firewall. This could be the result of a broken link. Very few people ever used it and I think that the default setting was Off.
This is what the setting options look like:
Hopefully @willcutforth can check/comment?
willcutforth
Fixes: 113
So I have tried having a look at the firewall link and it just white screens. the logo is there but nothing underneath. I will get this raised from our side to see why this is the case.
 Will Cutforth
