Safeguard not blocking a site
Scottonpc
I have Plusnet safeguard enabled on my Hub one. The block categories works fine, it's the block a website that doesn't, when I add a website to block it and refresh the page the website URL I added disappears and it's not blocked. I have restarted the router and tried adding any website to block it and the same issue occurs
23 REPLIES 23
Scottonpc
Re: Safeguard not blocking a site
I tried another web browser on my phone and once you have added a website to block, a save changes button appears at the bottom of the page which I didn't see initially. I have now received an email saying the Safeguard changes have now been updated. Resolved
Scottonpc
Unresolved, I just checked safeguard again and it's removed the site that I added to block. Please can Plusnet fix this
DerekW
How many website do you currently have in your blocked list?
Apparently you can only have 30 in total
"No one has ever become poor by giving" - Anne Frank
Scottonpc
Hi Derek,
I don't have any websites in my blocked list
Fixes: 476
Moderator's Note
This topic has been moved from Broadband to Everything Else
DerekW
How are you entering the web address?
You should use the following format. - website.com
Not need for any prefix such as https:// or www.
Scottonpc
Hi Derek,
That's the format I use, I have also tried it with the prefix
willcutforth
Fixes: 113
@Scottonpc  What's your DNS set to?
 Will Cutforth
Scottonpc
DNS is set to default, I haven't changed it
Fixes: 476
@Scottonpc
Which default? Safeguard uses its own DNS servers. I think that they are 213.120.234.42 and. 213.120.234.38
Scottonpc
My DNS is:
Primary DNS: 213.120.234.42
Secondary DNS: 213.120.234.38
Scottonpc
When I add any website to the block list I receive two confirmation emails that my safeguard settings have been updated and I have checked my safeguard change log and it shows:
05/09/2023 23:04 Your Blocked Websites list has changed
05/09/2023 23:02 Your Blocked Websites list has changed
Why is it removing the website to block after I've just added it to the block list?
James30
Fixes: 32
@Scottonpc - I can't see anything about your safeguard here only that it's enabled or disabled. Perhaps you could send some screenshots of what you have there now without changing anything. Perhaps that will shine some light on what's up with it?
James - Plusnet Sheffield
Scottonpc
Please see attached screenshots
