FTTP Static IP Address please
FIXED- Subscribe to RSS Feed
- Everything else
- FTTP Static IP Address please
23-12-2023 4:10 PM
Tried to set up Static IP on the web site but it appears not to have worked as others have found.
Can you set this up please. I dont wish the rDNS to point to the Plusnet account user name - just about anything else would do!
Fixed! Go to the fix.
Re: FTTP Static IP Address please
24-12-2023 11:37 AM
Hi @grnglide Sorry about the issue with that, I've hit some problems trying to add a static IP to your account too. Please bear with me and I'll try it again later today for you, failing that I'll need to speak to a colleague when back on shift on the 27th.
24-12-2023 11:47 AM - edited 24-12-2023 11:56 AM
Just noticed that the option to set up a static IP under Add-ons has disappeared leaving only "Plusnet Protect powered by Norton™"
27-12-2023 12:31 PM
Hey @grnglide
I've sorted out the issue with your account and assigned a static IP.
If you restart your router that should assign it to the connection for you.
28-12-2023 2:46 PM
28-12-2023 3:17 PM
- Everything else
