Static IP adress
Dsteve007
Static IP adress
Hi
I would like a static IP address. How would I go about this? I've read it doesn't work on the website. Is it a one off charge of £5?
Thank you
David
4 REPLIES 4
Fixes: 118
Re: Static IP adress
@Dsteve007
You either need to wait for a staff member to pick up this thread or phone support.
There is a one off cost of £5.00
MatthewWheeler
Fixes: 503
Hi @Dsteve007
If you're happy for us to add it on let us know
As of the 1st of January 2026, I no longer work in Plusne,t so I'll be unable to assist you with any queries.
Dsteve007
Hi Matthew.
Yes could add it please.
Thank you very much
David
MatthewWheeler
Fixes: 503
That's been done for you now @Dsteve007
If you reboot your router it'll pick it up
