Static IP adress
FIXEDTopic Options
- Everything else
- Re: Static IP adress
02-01-2024 6:25 PM
Hi
I would like a static IP address. How would I go about this? I've read it doesn't work on the website. Is it a one off charge of £5?
Thank you
David
Thank you
David
Fixed! Go to the fix.
Message 1 of 5
(1,544 Views)
4 REPLIES 4
03-01-2024 1:27 PM
You either need to wait for a staff member to pick up this thread or phone support.
There is a one off cost of £5.00
Message 2 of 5
(1,480 Views)
03-01-2024 1:55 PM
Hi @Dsteve007
If you're happy for us to add it on let us know
As of the 1st of January 2026, I no longer work in Plusne,t so I'll be unable to assist you with any queries.
Message 3 of 5
(1,475 Views)
03-01-2024 3:06 PM
Hi Matthew.
Yes could add it please.
Thank you very much
David
Thank you very much
David
Message 4 of 5
(1,460 Views)
03-01-2024 4:02 PM
That's been done for you now @Dsteve007
If you reboot your router it'll pick it up
Message 5 of 5
(1,448 Views)
